I've been having problems trying to build with the libsigc libraries, using intel compiler version 9. Trying to include headers from libsigc causes the compiler to crash, producing the message : 'internal error: backend signals'.
The crash occurs in preprocessing, just the line '#include "sigc++/signal.h"' is enough to cause it. The compile seems to break while including the libsigc file 'adaptor_trait.h', which is making heavy use of template classes.
The same code works with compiler version 7.1.
Any suggestions would be welcome! Thanks.
Message Edited by richc23 on 01-06-2006 07:37 AM
As always, compiler internal error, on a current version, is cause for submission of a formal problem report on your premier.intel.com account. I could guess that a failure seen only in a newer compiler might be provoked by attempting more optimization. Cutting back to a more conservative option might work around it, but you are entitled to ask for an investigation.
