Intel® C++ Compiler
7840 Discussions
Compiler Error "Segmentation violation signal raised."
seongyun_k_
I was using compiler version (compilers_and_libraries_2016.1.150), and I updated into (compilers_and_libraries_2017.0.098).
After the update, I cannot compile my application program due to the following compile error, which I cannot understand.
": internal error: ** The compiler has encountered an unexpected problem
** Segmentation violation signal raised. **
Access violation or stack overflow. Please contact Intel Support for assistance.
I cannot write a small program that reproduces the above error since 'I don't know what is causing the problem'.
I cannot provide the full code of my application program.
Where should I start taking a look at to find the cause?
Is there any debugging mode on icpc and mpiicpc compilers?
TimP
Black Belt
There is a 2017.1 compiler, in case this compiler bug may have been fixed.  Otherwise, there is not much you can do (besides following the advice about a problem report) but try less aggressive compile options (including possibly splitting source files with separate compilation).
James_T_Intel
I'm moving this to the correct forum.
JenniferJ
yes, if you get this error, it's a bug in the compiler.
Could you to help with the followings to isolate it more:
  1. remove the compilation options as much as possible
  2. lower the optimization level
  3. create the preprocessed file (adding -EP -P), and you'll see a .i file generated.
  4. file an issue report at Intel Premier Support with the .i and options.
thanks,
Jennifer
