Working on one project i've found strange bug: debug version of the project crashed with "Run-Time Check Failure #0 - The value of ESP was not properly saved across a function call".
So, i've found out that code(same fault):
[cpp]
void t2(int a)
return;
void t1()
t2(10);
__try
__except(1)
int main()
t1();
return 0;
[/cpp]
Compiler:
Intel(R) C++ Compiler for applications running on IA-32, Version 10.0 Build 20070426 Package ID: W_CC_P_10.0.025
Command line:
icl /c /Od /RTC1 /MDd /Gd main.cpp
xilink main.obj
After some diggin, i've found out following:
1. Call t1
2. Allocate all needed memory on stack
3. Save esp
4. Call t2 (pass arguments through stack)
5. Free stack memory ( arguments to t2() )
6. Restore esp
7. Compare esp, ebp // !!!! Houston, we've got troubles!
Asm listing is the following(only faulty code):
[plain]
push -1
push OFFSET FLAT: _try_info_pack0
push OFFSET FLAT: __except_handler3
push eax
sub esp, 18h
mov DWORD PTR [ebp - 18h], esp
add esp, 0
call t2
pop ecx
mov esp, DWORD PTR [ebp - 18h]
add esp, 24h
cmp ebp, esp
call __RTC_CheckEsp
[/plain]
Sample is the following:
[plain]
push eax;
mov dword ptr[ebp - 18h], esp;
pop eax;
mov esp, dword ptr[ebp - 18h];
cmp esp, ebp; // !!!!
[/plain]
Solution is rather simple: add this to the beginning of the t1():
[cpp]
__asm
nop;
[/cpp]
There is no crash after that, asm listings shows us correct code(memory allocates just before calling t1, frees just after):
[plain]
push -1
push eax
sub esp, 14h
push edi
call t2
pop ecx
add esp, 24h
cmp ebp, esp
call __RTC_CheckEsp
[/plain]
So, sample is the following:
[plain]
push eax;
pop eax;
cmp esp, ebp; // Good!
[/plain]
So, is it Compiler bug?
P.S.
Code crashes while calling any function t2() from t1(), if arguments to t2() were passed through stack.
P.P.S.
Compiling with version 11.1.035 solves problem, so i might think that it is compiler bug.
