Intel® C++ Compiler
7956 Discussions
Compiler crash (icpc 2016 update 1 and 2017 beta update 2)
Jorrit_F_
The compiler crashes for me when trying to compile the following program:
#include <array>
void test_invert_solve(std::array< std::array<double,3>, 3 > A,
                       std::array<double,3> x,
                       std::array<double,3> b)
  for (std::size_t i=0; i<3; i++)
    for (std::size_t j=0; j<3; j++)
      b -= A * x;
  for (auto be : b) {}
int main()
The error message looks like this:
-*- mode: compilation; default-directory: "~/Projekte/EXA-DUNE/patches/dune-common/dune/common/test/" -*-
Compilation started at Tue Jun 14 18:47:34
set -ex; CXX=/usr/local/bin/icpc-2017; $CXX --version; $CXX -std=c++14 -O3 -o fmatrixtest.o -c fmatrixtest.cc
+ CXX=/usr/local/bin/icpc-2017
+ /usr/local/bin/icpc-2017 --version
icpc (ICC) 17.0.0 20160517
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
+ /usr/local/bin/icpc-2017 -std=c++14 -O3 -o fmatrixtest.o -c fmatrixtest.cc
": internal error: ** The compiler has encountered an unexpected problem.
** Segmentation violation signal raised. **
Access violation or stack overflow. Please contact Intel Support for assistance.
compilation aborted for fmatrixtest.cc (code 4)
Compilation exited abnormally with code 4 at Tue Jun 14 18:47:34
This happens with "icpc (ICC) 16.0.1 20151021" too.
Operating system is Debian 8.5 "jessie", host compiler is "g++ (Debian 4.9.2-10) 4.9.2" in case that matters.
Anoop_M_Intel
Hi Jorrit,
Thanks for reporting this issue. I am able to reproduce this problem and I have escalated this to compiler engineering. Looks like the crash just happens in O3 optimization but not for O2.
Anoop
Anoop_M_Intel
This issue is fixed in 17.0 compiler which is available at Intel Registration Center.
Thanks and Regards
Anoop
