The compiler crashes for me when trying to compile the following program:
#include <array> void test_invert_solve(std::array< std::array<double,3>, 3 > A, std::array<double,3> x, std::array<double,3> b) { for (std::size_t i=0; i<3; i++) for (std::size_t j=0; j<3; j++) b -= A* x ; for (auto be : b) {} } int main() { }
The error message looks like this:
-*- mode: compilation; default-directory: "~/Projekte/EXA-DUNE/patches/dune-common/dune/common/test/" -*- Compilation started at Tue Jun 14 18:47:34 set -ex; CXX=/usr/local/bin/icpc-2017; $CXX --version; $CXX -std=c++14 -O3 -o fmatrixtest.o -c fmatrixtest.cc + CXX=/usr/local/bin/icpc-2017 + /usr/local/bin/icpc-2017 --version icpc (ICC) 17.0.0 20160517 Copyright (C) 1985-2016 Intel Corporation. All rights reserved. + /usr/local/bin/icpc-2017 -std=c++14 -O3 -o fmatrixtest.o -c fmatrixtest.cc ": internal error: ** The compiler has encountered an unexpected problem. ** Segmentation violation signal raised. ** Access violation or stack overflow. Please contact Intel Support for assistance. compilation aborted for fmatrixtest.cc (code 4) Compilation exited abnormally with code 4 at Tue Jun 14 18:47:34
This happens with "icpc (ICC) 16.0.1 20151021" too.
Operating system is Debian 8.5 "jessie", host compiler is "g++ (Debian 4.9.2-10) 4.9.2" in case that matters.
Hi Jorrit,
Thanks for reporting this issue. I am able to reproduce this problem and I have escalated this to compiler engineering. Looks like the crash just happens in O3 optimization but not for O2.
Anoop
This issue is fixed in 17.0 compiler which is available at Intel Registration Center.
Thanks and Regards
Anoop
