I installed parallel_studio_xe_2015_update3 on my debian jessie on linux, and when i'm trying to compile the code I'm working on with icpc, there is this strange error :
/usr/include/c++/4.9/sstream(564): internal error: assertion failed at: "shared/cfe/edgcpfe/lower_init.c", line 5243
~basic_stringstream()
with no links to my code or anything else.
What did I missed?
Config:
kernel version 3.16.0-4-amd64
libstdc++6
g++ 4.9.2 also installed (no issues with this compiler)
Thanks for your help I'm stuck with this problem.
Johan
Hello Johan,
with 15.0.3 and GCC 4.9.3 (did not have 4.9.2 at hand) I'm not able to reproduce this.
Could you please provide me a preprocessed output of the failing compilation? The smaller the file, the better. Please also enclose the compiler options. If you don't want to disclose the file you can send me a direct message.
The fail is a bug in the C/C++ compiler front-end.
Thank you very much,
Georg Zitzlsberger
Topic Options
