Hi there, the following error prevents me to compile my project. Here is the output:
1>------ Rebuild All started: Project: MyProject, Configuration: Release x64 ------
1> StdAfx.cpp
1> 102042.cpp
1> 102042.cpp
1> 102042.cpp
1> 102042.cpp
1> 102042.cpp
1> 102042.cpp
1> 102042.cpp
1>C:\\Program Files (x86)\\MSBuild\\Microsoft.Cpp\\v4.0\\Platforms\\x64\\PlatformToolsets\\Intel C++ Compiler XE 12.0\\Microsoft.Cpp.x64.Intel C++ Compiler XE 12.0.targets(88,5): error : backend signals
1>
1> compilation aborted for StdAfx.cpp (code 4)
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
I have turned off precompiled headers and still get the same error.
Any ideas what I can do?
Christian
I'll get back to you when I cannot fix it myself.
Thanks for your answer,
Christian
Here is the code.
And the output from my command line:
Om
Intel Compiler support
Thanks for taking the time to create a reproducer.
I have reduced the example further to this standalone test case:
template
struct Pair
Pair(const _Ty1&, const _Ty2& _Val2) : second(_Val2) {}
_Ty2 second;
struct HOBJ
HOBJ();
HOBJ( const HOBJ& src );
struct Value
#ifdef OK
struct S
#else
struct
#endif
HOBJ h[2];
int main()
Pair
return 0;
As a workaround you can change the structure to a non-anonmyous struct (see #ifdef OK in example above).
BTW, it is illegal according to the C++ standard to declare anonymous structs. But since Microsoft allows this we do too.
