Intel® C++ Compiler
7779 Discussions
Compiler flag to disable all vectorization?
lmeyerov2
Is there a way to disable vectorization as a compiler flag (overriding and pragmas in the code)? Ideally it would leave instrinsics in place (or use a software interpretation..), but not as big a deal.
Thanks!
TimP
Black Belt
Is /Qvec- not what you want? I don't understand your comment about intrinsics. /Qvec- would prevent implicit invocation of svml (short vector library) functions.
lmeyerov2
It looks like "/Qvec-" what I was mostly looking for (had been trying "/vec-").
For intrinsics, I'd hope something like "_m128i a = _mm_load_si128(b);" gets expanded into normal instructions (in this case, multiple loads into a regular register) instead of SSE ones (movdqa into an xmm).
JenniferJ
if you do not want any SSE instructions in the code, you should use /arch:IA32.
I don't think theicl will convert the SSE intrinsics to x86 instructions for you automatically though.
Jennifer
jimdempseyatthecove
Black Belt
Jennifer et al,
Perhapse one could use
#pragma vector never
do {
} while(false);
However, you consider permitting
{ // for duration of scope
} // #pragma vector never
Current documentation indicate pragma is followed by loop.
The scoping feature will extend across functions too
(similar to how one uses:
extern "C" {
} // extern "C" {
surrounding multiple functions.
Jim Dempsey
Om_S_Intel
The following pragma is new feature request:
We will discuss this win the internal team. If many customers are looking for this them we may cosider implementing this in the Intel compiler.
