I am hitting an internal compiler error IERROR_MODULE_ID_1204 with icl 14.0.2 on Windows (64-bit compiles) when using -Qstd=c++11 and optimization (-O1 or above) on a few places in a large application. I have had a hard time boiling it down to a trivial example and I can't yet eliminate a dependency on some external code, but to start the conversation here is the demo code:
// Compile with Intel C++ for Windows 14.0.2 using icl -Qstd=c++11 -O1 -c // Fails: internal error: IERROR_MODULE_ID_1204 // Without -Qstd=c++11 or with -Od it succeeds #include <cmath> #include <ObjexxFCL/FArray1D.hh> void foo() { static double c( 0.0 ); static double t( 123.456 ); int const N( 20 ); ObjexxFCL::FArray1D< double > v; for ( int d = 1; d <= N; ++d ) { for ( int w = 1; w <= N; ++w ) { c = std::pow( t, 4 ); } } }
I can provide the external code to Intel developers privately when they are ready to work on the issue.
Stuart
Hi Stuart,
Thank you for your efforts in creating a small example. In order to reproduce the error, I need you to do one more thing. Assuming filename of the example is test.cpp, please create a preprocessed source file, by typing
> icl -Qstd=c++11 -E test.cpp > test-prep.cpp
Please upload test-prep.cpp in this issue. If your header files may proprietary source code, please send me a private message.
Thanks Feilong. I sent you the requested file via private message.
Stuart,
Thank you for your test case. I've reproduced the problem and entered this issue to our problem-tracking database. I'll let you know when I have an update from engineering team.
Hi Stuart,
I was notified that this issue has been resolved in Intel Parallel Studio XE 2015. You may download it in https://registrationcenter.intel.com
