Hello and a happy new year
I try to enable multi processor compilation for my project.
This works fine with the VS compiler, by adding the option /Gm-
After switching to the intel compiler it uses only one core.
The option /MP is set.
Among the comiler options i can not find one that is comparable to the VS /Gm option.
No warning is shown during the compile process.
Win 7 / 64
VS 2010
Intel XE 12.1
Moving the whole project to my laptop, which is running win 10 Enterprise, everything works perfect.
kind regards
Peter
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
The compiler version 12.1 is no longer supported. Please upgrade to the latest ones.
Thanks my friend, this was very helpful.
Hi guys
i followed your advice and downloaded XE 2018 - because i use VS2015 enterprise and don't want to upgrade.
Uninstalled XE 12.1 and run the install package. It crashed with with the message "intel software setup assistant doesn't work anymore".
No error code or anything.
Trying to reinstall the old compiler afetr that crashed too?
ASUS dual cpu board Z10PE-D8
2 x XEON E5 2699V4
128 GB ram
Win 7 professional 64 Bit
any ideas?
Peter
Not so sure what happened with your system. Do you have another machine to install?
