Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
7702 Discussions
Compiler perfomance in Linux vs Windows
chera64
I want to start my new project with ICC, I can work in windows and Linux.
Is there is any difrence between speed and perfomnace of compiled program in windows or linux?
Thansks,
TimP
Black Belt
Generally speaking, there is no large difference in performance of the same program compiled for similar levels of Windows or linux OS. We expect a Windows version to give 95% of the performance of an equivalent linux version. Perhaps the first exception which might be mentioned is that Windows versions prior to Windows 7 don't schedule as efficiently as any recent linux when run on HyperThread or multi-CPU platforms.
chera64
Quoting - tim18
thanks,
1- is there any exception, if i want to use parallel processing wildly?
2-Is windows server 2008 schedules efficient as recent linux? or it should be 2008 R2?
TimP
Black Belt
Quoting - chera64
thanks,
Windows has both advantages and disadvantages for parallel processing. Intel Parallel Studio is available only for Windows; it is meant to facilitate parallelization for C and C++.
Linux has more alternative tools for parallel debugging and thread affinity, not limited to those from Intel or Microsoft and a few others, with more public support.
A majority of the Intel software tools are designed to operate consistently in either linux or Windows versions.
Windows 2008 R2 is recommended for efficient multi-processing scheduler. We demonstrated it successfully on the 32-core platform, both with HyperThreading (64 logical processors) and without.
chera64
Quoting - tim18
Quoting - chera64
thanks,
So, I searched for Intel parallel studio,
Is Intel parallel studio useful for a shared memory systems and I can not use it in distributed system?
TimP
Black Belt
Quoting - chera64
That's right, parallel studio uses OpenMP and IPP. It's an aid to adding OpenMP parallelization, within the framework of the Intel C++ compiler. The Professional Compiler has all the OpenMP IPP and TBB features, but not the added features for investigating how to add parallelism. More detailed questions should be asked on Parallel Studio forum.
For cluster systems, Intel MPI library works consistently in Windows and linux versions. In principle, you could use it with Parallel Studio, except that MPI applications often require Fortran.
There's also a Cluster OpenMP (cluster extension of OpenMP) feature for the standard Intel compilers, supported on WhatIf forum. It trades the scalability of MPI for simplicity and similarity to OpenMP.
joelkatz
Quoting - chera64
Thansks,
It's not that difficult to keep your code portable. I suggest you do that, for several reasons. One is that you can actually compare the performance on Linux and Windows. If, for some reason, the performance on one platform is way off from the performance of the other, you'll know something odd is going on (and it will be easier to compare performance analysis to see where it diverges). You'll be able to use debugging and analyzing tools on both platforms as well.
