Hi.
I'm currently set to compile and install a tool named "SEPlib" version 6.5.3. And everything seems to work fine, until I get a rather cryptic error code from the Intel compiler: "internal error: backend signals", and on the next line this error: "icc: error #10014: problem during multi-file optimization compilation (code 4)".
I have tryied to Google the problem, and I don't think it's related to the tool which I'm compiling. Below I've attached a snippet of the compiling output.
I am using the Intel v10 "em64t" compiler, on a RedHat Enterprise Linux release 4. The "uname -a" output this:
Linux st-lccapp01 2.6.9-34.ELsmp #1 SMP Fri Feb 24 16:56:28 EST 2006 x86_64 x86_64 x86_64 GNU/Linux
====== Compiling output ======
Copy_split.c(76): (col. 3) remark: LOOP WAS VECTORIZED.
Copy_split.c(269): (col. 7) remark: LOOP WAS VECTORIZED.
/bin/sh ../../libtool --mode=link --tag=CC icc -g -O2 -L../../../seplib_base/lib/corelibs/sep -L../../../seplib_base/lib/corelibs/sep3d -L../../../seplib_base/lib/corelibs/superset -L../../../vplot/libvplot -L../../../seplib_base/lib/graphics/glplot -L../../../seplib_base/lib/class/gee -L../../../seplib_base/lib/util/math -L../../../seplib_base/lib/util/sepaux -L../../../seplib_base/lib/util/fft -L../../../seplib_base/lib/util/par -L../../../seplib_base/lib/util/vector -L../../../seplib_base/lib/util/convert -L../../../seplib_base/lib/seis/travel -L../../../seplib_base/lib/seis/velan -L../../../seplib_base/lib/seis/filter -L../../../seplib_base/lib/seis/image -L../../../seplib_base/lib/seis/wei -L../../../seplib_base/lib/seis/dip -L../../../seplib_base/lib/util/cwp -L../../../seplib_base/lib/seis/model -L../../../seplib_base/lib/util/sergey -o Copy_split Copy_split.o -lsuperset_mpi -lsepaux -lsep3d -lsep -lseppar_mpi /prog/sdpsoft/openmpi-1.2.6/lib/ -lm
mkdir .libs
icc -g -O2 -o Copy_split Copy_split.o /prog/sdpsoft/openmpi-1.2.6/lib/ -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/corelibs/sep -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/corelibs/sep3d -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/corelibs/superset -L/private/pgadm/PSDM/seplib-6.5.3/trunk/vplot/libvplot -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/graphics/glplot -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/class/gee -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/util/math -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/util/sepaux -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/util/fft -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/util/par -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/util/vector -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/util/convert -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/seis/travel -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/seis/velan -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/seis/filter -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/seis/image -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/seis/wei -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/seis/dip -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/util/cwp -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/seis/model -L/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/util/sergey /private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/corelibs/superset/.libs/libsuperset_mpi.a /private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/util/sepaux/.libs/libsepaux.a /private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/corelibs/sep3d/.libs/libsep3d.a /private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/corelibs/sep/.libs/libsep.a /private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_base/lib/util/par/.libs/libseppar_mpi.a -lm
(0): internal error: backend signals
gmake[3]: *** [Copy_split] Error 4
gmake[3]: Leaving directory `/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_prog/util/par'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory `/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_prog/util'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/private/pgadm/PSDM/seplib-6.5.3/trunk/seplib_prog'
make: *** [all-recursive] Error 1
[pgadm@st-lccapp01 trunk]$ icc -v
Version 10.0
Any help would be deeply appreciated.
Hi.
mkdir .libs
Version 10.0
This kind of annoying error was more prevalent in the 10.0 compiler than in current versions. If you have a standard license, register it at https://registrationcenter.intel.com and download an update, at least one within the last 6 months. 11.0 should be available by mid-month.
Thanks for the reply tim18.
I've now instructued the IT-department to download and install the latest update for the v10 compiler. Hopefully this would work.
