I have an Intel Core Duo (T2350)
CPU. I'm running Ubuntu 9.10 Karmic Koala. I am using icc version 11.1 to compile some OpenCV code I made (using the i386 Ubuntu repository version).
When I compile the code with:
icc `pkg-config --cflags opencv` `pkg-config --libs opencv` edge_v2.cpp -vec-report
I receive errors:
/usr/local/include/opencv/cxmat.hpp(346): warning #68: integer conversion resulted in a change of sign
if( refcount && CV_XADD(refcount, -1) == 1 )
/usr/local/include/opencv/cxmat.hpp(3722): warning #68: integer conversion resulted in a change of sign
/usr/local/include/opencv/cxmat.hpp(4116): warning #68: integer conversion resulted in a change of sign
if( hdr && CV_XADD(&hdr->refcount, -1) == 1 )
What does this mean? How do I go about correcting this? Any help would be much appreciated.
CV_XADD on x32 is int (__int32), and on x64 is long (__int64). The first arg is an address of volatile version of the int/long and the second arg is of type int/long. Assure that refcount is of proper type as well as the literals. -1 and 1are int not long (if you are compiling for x64).
Quoting - jimdempseyatthecove
The warning is not about integer size but about signedness.
Cause:
Conversion of integer resulted in sign change. Usually this happens when an unsigned integral
type was assigned -1.
Example:
unsigned inti = -1;
Resolution:
Conversion from a signed int to unsigned leads to change of sign. This
might result in an unexpected behavior of the code. If the sign of the
integer is not a concern, then this diagnostic can be ignored.
Otherwise, do not assign a signed value to unsigned type.
