I'm trying to compile VLC2.0 on Ubuntu 11.10, and am stumped with this error. I've already successfully compiled all of the dependencies in vlc-2.0.0/contrib/, using the latest Intel compiler suite. However, I'm getting an error when compiling (or is it linking?) src/posix/filesystem.c
Configured VLC with:-
[bash]../configure \ --host="x86_64-linux-gnu" \ --build="x86_64-linux-gnu" \ --enable-shared --enable-gpl \ --enable-version3 --enable-nonfree \ --enable-gnutls --enable-libass \ --enable-libbluray --enable-libcdio \ --enable-libdirac --enable-libfaac \ --enable-libfreetype --enable-libmp3lame \ --enable-libopenjpeg --enable-libpulse \ --enable-librtmp --enable-libschroedinger \ --enable-libspeex --enable-libtheora \ --enable-libvo-aacenc --enable-libvorbis \ --enable-libx264 --enable-libxvid \ --enable-openssl --enable-openal[/bash]
I've edited some of the flags in the makefile; relevant flags are now:
[bash]CC = icc -std=gnu99
CFLAGS = -O3 -ipo -I/usr/local/src/vlc-2.0.0/contrib/x86_64-linux-gnu/include -Wall -Wextra -Wsign-compare -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -funroll-loops -fomit-frame-pointer -finline -finline-limit=1000
CPP = icc -E
CPPFLAGS = -I$(top_srcdir)/include -I$(top_builddir)/include -I/usr/local/src/vlc-2.0.0/contrib/x86_64-linux-gnu/include
CXX = icpc
CXXCPP = icpc -E
CXXFLAGS = -O3 -std=gnu99 -xHost -I/usr/local/src/vlc-2.0.0/contrib/x86_64-linux-gnu/include -Wall -Wextra -Wsign-compare -Wpointer-arith -Wvolatile-register-var -fvisibility=hidden -funroll-loops -fomit-frame-pointer
[/bash]
During the make stage I get this error:
[bash]CC posix/filesystem.lo
../../src/posix/filesystem.c(300): warning #589: transfer of control bypasses initialization of: variable "ln" (declared at line 302)
goto error;
^ /usr/include/bits/fcntl2.h(44): error #18015: invalid use of '__builtin_va_arg_pack_len'
/usr/include/bits/fcntl2.h(57): error #18015: invalid use of '__builtin_va_arg_pack_len'
/usr/include/bits/fcntl2.h(60): error #18015: invalid use of '__builtin_va_arg_pack'
/usr/include/bits/fcntl2.h(120): error #18015: invalid use of '__builtin_va_arg_pack_len'
/usr/include/bits/fcntl2.h(133): error #18015: invalid use of '__builtin_va_arg_pack_len'
/usr/include/bits/fcntl2.h(136): error #18015: invalid use of '__builtin_va_arg_pack' compilation aborted for ../../src/posix/filesystem.c (code 1)
[/bash]
Having looked around online, I've seen a couple mail-lists mentioning optimisation flags causing this error with gcc, specifically flags involved with inlining, which is why I added:-
-ipo -finline -finline-limit=1000 to CFLAGS.
This doesn't seem to solve the problem though.
Can anyone help me solve this??
I've tried to figure out the exact compile/libtool command used by the makefile, in order to compile filesystem.lo manually, but I can't find a way to getmaketo print the exact command used, even withmake -d.
I did manage to compile filesystem.c, but it made an ELF 64bit executable, rather than a libtool object file, so I still couldn't get past this step...
Any help much appreciated!
Kind regards,
Alex
ps. I've asked this question on stackoverflow, but figured I might get a quicker response here...
Do you have some code that reproduces the problem?
thanks
Judy
