I have the Intel C++ 10.1 compiler installed on Debian Linux.
I want to compile a program and run it on a 64 bit machine:
Intel Xeon CPU, X5355 @ 2.66GHz
I can't for the life of me find the compiler flags I need. Here are the ones I have so far:
-Wp64 -Ap64 -As64
(I've been trying everything).
If someone could help me, this would be a huge help as I've been banging my head way too long looking for the correct flag.
I've been able to compile for the 64 bit machine before by using the -xT flag, but the 64 bit machine executes the program as a 32 bit program (so sizeof(void*) == 4 instead of 8).
Yes, if you compile with the 32-bitcompiler, and provide all required .so, you can run on both 32- and 64-bit OS in 32-bit mode. -xT is certainly not required, although all recent x86-64 systems support at least -xO (-xW for early AMD). 64-bit cross compilation on 32-bit linux is possible in principle, but not supported. For starters, you would have to copy over a bunch of libraries from a 64-bit linux installation, and you would have to set up some version of gcc/g++ cross compiler, at least to the extent that icc finds the 64-bit libraries when it asks g++ where to find them, and finds a cross linker.Given that cross compilation for 64-bit from 32-bit linux hasn't been supported, icc-64 will change soon to a 64-bit compiler, eliminating the slight possibility of cross compilation.
Intel and others found out several years ago that there is little demand for building 64-bit applications on a 32-bit system, and the designers of the x86_64 OS never attempted to facilitate cross compilation (except for the other direction).
