hello, I'm not sure what is going on here. I just installed c++ compser xe 2013.0.079 and integrated it into Eclipse on linux. When I try to build a test application which links to a shared library I get an error saying ld: cannot find -lfoo.so. foo.so does exit in the specified directory and I've added the library directory to the search path in the project->properties in settings->Intel 64 C++ Linker->Libraries tab. I've also appended the library directory to LD_LIBRARY_PATH. In addition, I tried building on just the command line outside of eclipse and get the same error. What am I doing wrong?
Here is the compiler output:
make -k all
Building file: ../src/test.cpp
Invoking: Intel Intel(R) 64 C++ Compiler
icpc -I/home03/eclipse_workspace/foo/src -MMD -MP -MF"src/test.d" -MT"src/test.d" -c -o "src/test.o" "../src/test.cpp"
Finished building: ../src/test.cpp
Building target: Intel_cpp_test
Invoking: Intel Intel(R) 64 C++ Linker
icpc -L/home03/eclipse_workspace/foo/Release -o "Intel_cpp_test" ./src/test.o -lfoo.so
