Intel® C++ Compiler
7833 Discussions
Compiling boost::lexical_cast with Intel Compiler with optimizations causes a win32 exception
bstrouse
This was mentioned a few months ago by another poster, but I saw no resolution for his post:
http://software.intel.com/en-us/forums/showthread.php?t=81574&o=a&s=lr&wapkw=%28Intel+Threading+Tools+Boost+Performance%29
Here is my simple program:
#include
#include
#include
int main()
int digit = 5;
try
std::string digitString = boost::lexical_cast<:STRING>(digit);
catch (boost::bad_lexical_cast &ex)
std::cout << "Exception: " << ex.what() << std::endl;
When I compile this program in debug mode of MS visual studio 2008, the program runs successfully. However, in release mode with any optimizations turned on, the program produces an unhandled win32 exception. Compiling the same program in debug and release mode with O2 (optimize for speed) using the visual C++ compiler in visual studio successfully runs the program with no exceptions.
Is this a bug in the Intel compiler regarding boost::lexical_cast?
JenniferJ
I did some investigating. the issue is related to /Qipo. Original posting has /Qipo.
Checked with /Qip, it worked. please use the /Qip for now. I will file a bug report about it.
thanks for reporting again.
Jennifer
JenniferJ
This issue does not happen with 12.1 any more. Some other fixes solved the issue.
Please use the Intel C++ Composer XE 12.0 update 6 orupdate 7.
Jennifer
