Intel® C++ Compiler
Compiling qhull
Fabio_G_
Dear all,
I'm trying to compiler qhull http://www.qhull.org/. I edited the makefile
by specifying CC = icc and CXX = icpc, I've thought it was enough.
However the compilation fails. There are an additional options for CC/CXX
CC_OPTS1  = -O2 -fPIC -ansi -Isrc/libqhull $(CC_WARNINGS)
CXX_OPTS1 = -O2 -Dqh_QHpointer -Isrc/ -Isrc/libqhullcpp -Isrc/libqhull $(CXX_WARNINGS)
the warning switches are
CC_WARNINGS  = -Wall -Wcast-qual -Wextra -Wwrite-strings -Wshadow
CXX_WARNINGS = -Wall -Wcast-qual -Wextra -Wwrite-strings -Wno-sign-conversion -Wshadow -Wconversion
The (main) error occurs at line (106) of qhull-2012.1/src/libqhull/qhull_a.h, i.e. at
#if defined(__INTEL_COMPILER) && !defined(QHULL_OS_WIN)
template <typename T>
inline void qhullUnused(T &x) { (void)x; }
#  define QHULL_UNUSED(x) qhullUnused(x);
#else
#  define QHULL_UNUSED(x) (void)x;
#endif
I cannot figure what is the solution. Can anyone help me?
Thank you, very much.
Fabio
Judith_W_Intel
Can you please tell us what error you are seeing and attach the preprocessed source so we can see what the macro is being expanded to?
thanks,
Judy
Fabio_G_
Well, launching icc -EP qhull_a.h it gives a long output and the macro expand as
It is a template function and nothing seems to be missing.
The output of full compilation is quite short
mkdir -p bin lib
icc -c -O2 -fPIC -ansi -Isrc/libqhull -Wall -Wcast-qual -Wextra -Wwrite-strings -Wshadow -o src/rbox/rbox.o src/rbox/rbox.c
icc -c -O2 -fPIC -ansi -Isrc/libqhull -Wall -Wcast-qual -Wextra -Wwrite-strings -Wshadow -o src/libqhullstatic/global.o src/libqhull/global.c
src/libqhull/qhull_a.h(106): warning #77: this declaration has no storage class or type specifier
src/libqhull/qhull_a.h(106): error: expected a ";"
src/libqhull/qhull_a.h(115): warning #12: parsing restarts here after previous syntax error
  void    qh_qhull(void);
compilation aborted for src/libqhull/global.c (code 2)
make: *** [src/libqhullstatic/global.o] Errore 2
Thanks!
However, I am looking for a ND Delaunay triangulator, do someone know kinda-of working with ICC??
Judith_W_Intel
It looks like you are compiling a C++ file with icc not icpc.
Judy
Judith_W_Intel
Either that or there's a bug in the header file that causes it to only work for C++ (since templates are a C++ only feature).
Fabio_G_
@Judith: Thanks, it could be. I'll try to force C++ compilation on whole code.
Does someone know a working C routine for n-dimensional Delaunay triangulation?
bernaske
Hi
i have download qhull and compiled with Parallel Studio XE 2013 ( Compiler Version 14.0.2 )
no problems.
1) cmake CMakeLists.txt
2) build with
make CC=icpc CXX=icc
no problems , correct compile, build all,
testqset works normal, q_test works normal
i use as environment:
Linux openSUSE 13.2 Milestone 0 64 Bit (x86_64) Kernel 3.14.0-5, KDE 4.13, XServer 11.0 NVIDIA Driver 334.21
icc (ICC) 14.0.2 20140120
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
icpc (ICC) 14.0.2 20140120
