Any program compiled with icc18 on AMD CPU with "-fast" option results in executable that produces the following error when launched:
Please verify that both the operating system and the processor support Intel(R) X87, CMOV, MMX, FXSAVE, SSE, SSE2 and SSE3 instructions.
CPU information from the OS (no SSE3 there): > head /proc/cpuinfo -n 26 processor : 0 vendor_id : AuthenticAMD cpu family : 16 model : 9 model name : AMD Opteron(tm) Processor 6174 stepping : 1 cpu MHz : 2200.000 cache size : 512 KB physical id : 0 siblings : 12 core id : 0 cpu cores : 12 apicid : 16 initial apicid : 0 fpu : yes fpu_exception : yes cpuid level : 5 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm 3dnowext 3dnow constant_tsc rep_good nonstop_tsc extd_apicid amd_dcm pni monitor cx16 popcnt lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt nodeid_msr bogomips : 4399.72 TLB size : 1024 4K pages clflush size : 64 cache_alignment : 64 address sizes : 48 bits physical, 48 bits virtual power management: ts ttp tm stc 100mhzsteps hwpstate
Looks like this is against the specification of "-fast" in the manual:
> icc -help | egrep "\-fast|\-x" -A1 -fast enable -xHOST -O3 -ipo -no-prec-div -static -fp-model fast=2 -- -x<code> generate specialized code to run exclusively on processors indicated by <code> as described below -- -xHost generate instructions for the highest instruction set and processor available on the compilation host machine
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Looks like this is a known issue and will be fixed in the next compiler update.
Thanks!
