When I compiled my code( c and C++) with g++ there is no problem. But when I compiled with Intel compiler using icc I'm getting the below error.
(I used Intel compiler to implenment OpenMP, as GCC will not support OpenMP.)
My program uses STL, so initialling I thought it is because of STL, as it does not support all compilers. So I installed STLport for Intel compiler. But the error persist.
icc -openmp -c renamemulti.C
/opt/intel/compiler70/ia32/include/xhash(126): error: call of an object of a class type without appropriate operator() or conversion functions to pointer-to-function type
return (!_Keyeqobj(_Keyval1, _Keyval2));
detected during:
instantiation of "bool std::_Hash_compare<_Kty, _Keyeq>::operator()(const _Kty &, const _Kty &) const [with _Kty=int, _Keyeq=std::allocator<:PAIR>
instantiation of "std::_Hash<_Tr>::_Pairib std::_Hash<_Tr>::insert(const std::_Hash<_Tr>::value_type &) [with _Tr=std::_Hmap_traits
instantiation of "std::hash_map<_Kty, _Ty, std::hash<_Kty>, _Keyeq>::mapped_type &std::hash_map<_Kty, _Ty, std::hash<_Kty>, _Keyeq>::operator[](const std::hash_map<_Kty, _Ty, std::hash<_Kty>, _Keyeq>::key_type &) [with _Kty=int, _Ty=int, _Keyeq=std::allocator<:PAIR>
make: *** [renamemulti.o] Error 2
[kolli@ariadne multi]$
Dear Vijaya,
First thing to do is to rule out OpenMP. You should be able to compile without openmp; you'll get a number of 'unrecognized pragma' warnings, but you should be o.k.
Afterwards, I'd try and cut down the testcase using a tool such as icpi (part of the Intel compiler distribution). Once you do that and verify that gcc still compiles, you should have something that you can submit to premier support. It may also be the case that your code is not 100% legit. Having a small testcase can help in the determination.
Max
This is the place in my code where I'm getting error,
hash_map< int, int, hash
When I used icpi instead of icc
icpi -c renamemulti.C
icpi on Linux-IA32: 2.0.0.3
Compilation Problem Isolator build 1.0_11052001_3
Build date stamp: 17:29:59 Feb 26 2002
ICPI main file: CRMain.cpp
Logfile Path is: renamemulti.C.cpi.log
ERRORFILE NAME: renamemulti.C.cpi.err
Matching Criteria from default strings
StringArray Contents
|: error|
|internal error :|
|internal error:|
|Illegal READ|
|Illegal WRITE|
|compiler error:|
|Compiler error:|
|: catastrophic error:|
|Catastrophic error:|
|FATAL ERROR : Compiler Internal Error|
10 Strings Total
icpi -o treeinput renamemulti.o med.o Ograph.o Pair.o CompInfo.o Cycle.o Component.o ins-selection.o gencov.o SortSeq.o multiMED.o perfEval.C -lm
Logfile Path is: -lm.cpi.log
ERRORFILE NAME: -lm.cpi.err
|: error|
|internal error :|
|internal error:|
|Illegal READ|
|Illegal WRITE|
|compiler error:|
|Compiler error:|
10 Strings Total
ERROR: Something strange happened
ERROR: Cannot open input file -lm
TOTAL TIME FOR EVERYTHING: 0:0:0
FileOrg Compiler Time in seconds: 0
Error found and isolated
renamemulti.fut.C(3): error: type name is not allowed
renamemulti.fut.C(4): error: type name is not allowed
renamemulti.fut.C(4): error: expected an expression
renamemulti.fut.C(7): error: identifier "beenseen1" is undefined
if(beenseen1[abs(s1)])
renamemulti.fut.C(7): error: identifier "abs" is undefined
renamemulti.fut.C(8): error: identifier "doremap" is undefined
doremap[abs(s1)] = 1;
compilation aborted for renamemulti.fut.C (code 2)
Compiler failed for this file.
Dear Vijaya,
icpi is a tool that helps prune down your testcase into a smaller sized file.I'm not sure you used the tool correctly.Can you browse the documentation and let me know if you have questions?
Max
Dear Vijaya,
Can you file a premier support issue on it? That is the fastest way to get the most qualified people looking at your problem.
Max
Right now I'm using my college servers, to work on Linux, but I have userid and password for premier support for Windows version(as I recently downloaded 30day evaluation version). Can I use that to post the question.
Do I have to describe the whole problem to the premier support and attach the code.
Thank you
Dear Vijaya,
It is important that the testcase you submit reproduce your original error. To do so, I would suggest removing the #include from the .C file. In addition, you probably need a
#include
using namespace std;
at the top of the file. So, before submitting to Premier, make sure your small testcase reproduces the problem you are interested in.
Max
