I am running the following program -
#include<iostream> #include<omp.h> using namespace std; int main(){ unsigned i; #pragma omp parallel for for(i=0 ;i < 20 ;i++) cout<<"Thread id: "<<omp_get_thread_num()<<" i value: "<<i<<endl; return 0; }
g++ -fopenmp test_omp.cpp
/tmp/ccIuzTDT.o: In function `main':
test_omp.cpp:(.text+0x19): undefined reference to `GOMP_parallel'
collect2: error: ld returned 1 exit status
https://software.intel.com/en-
I have confirmed that the error is not due to any other packages installed.
Please help me to remove the complete Intel Runtime library.
This doesn't appear to be a problem which could be provoked by icc installation.
Agree with Tim, Intel runtime library will be installed in different path So icc installation may not disturb the g++ environment.
Can you please check the gcc's libgomp.so installed path ? Something as below.
#g++ -fopenmp -Wl,-y,GOMP_parallel ompdll.cpp
/tmp/cct09q9u.o: reference to GOMP_parallel
/lib/gcc/x86_64-unknown-linux-gnu/5.2.0/../../../../lib64/libgomp.so: definition of GOMP_parallel
#icpc -fopenmp -Wl,-y,GOMP_parallel ompdll.cpp
../compiler/lib/intel64/libiomp5.so: definition of GOMP_parallel
Reddy
sudo locate libgomp.so
/home/ankita/cilkplus-gcc/b-gcc/prev-x86_64-unknown-linux- gnu/libgomp/.libs/libgomp.so
/home/ankita/cilkplus-gcc/b-gcc/prev-x86_64-unknown-linux- gnu/libgomp/.libs/libgomp.so.1
/home/ankita/cilkplus-gcc/b-gcc/prev-x86_64-unknown-linux- gnu/libgomp/.libs/libgomp.so. 1.0.0
/home/ankita/cilkplus-gcc/b-gcc/stage1-x86_64-unknown- linux-gnu/libgomp/.libs/ libgomp.so
/home/ankita/cilkplus-gcc/b-gcc/stage1-x86_64-unknown- linux-gnu/libgomp/.libs/ libgomp.so.1
/home/ankita/cilkplus-gcc/b-gcc/stage1-x86_64-unknown- linux-gnu/libgomp/.libs/ libgomp.so.1.0.0
/home/ankita/cilkplus-gcc/b-gcc/x86_64-unknown-linux-gnu/ libgomp/.libs/libgomp.so
/home/ankita/cilkplus-gcc/b-gcc/x86_64-unknown-linux-gnu/ libgomp/.libs/libgomp.so.1
/home/ankita/cilkplus-gcc/b-gcc/x86_64-unknown-linux-gnu/ libgomp/.libs/libgomp.so.1.0.0
/home/rintu/Galois/gcc-4.8.4/prev-x86_64-unknown-linux-gnu/ 32/libgomp/.libs/libgomp.so
/home/rintu/Galois/gcc-4.8.4/prev-x86_64-unknown-linux-gnu/ 32/libgomp/.libs/libgomp.so.1
/home/rintu/Galois/gcc-4.8.4/prev-x86_64-unknown-linux-gnu/ 32/libgomp/.libs/libgomp.so.1. 0.0
/home/rintu/Galois/gcc-4.8.4/prev-x86_64-unknown-linux-gnu/ libgomp/.libs/libgomp.so
/home/rintu/Galois/gcc-4.8.4/prev-x86_64-unknown-linux-gnu/ libgomp/.libs/libgomp.so.1
/home/rintu/Galois/gcc-4.8.4/prev-x86_64-unknown-linux-gnu/ libgomp/.libs/libgomp.so.1.0.0
/home/rintu/Galois/gcc-4.8.4/stage1-x86_64-unknown-linux- gnu/32/libgomp/.libs/libgomp. so
/home/rintu/Galois/gcc-4.8.4/stage1-x86_64-unknown-linux- gnu/32/libgomp/.libs/libgomp. so.1
/home/rintu/Galois/gcc-4.8.4/stage1-x86_64-unknown-linux- gnu/32/libgomp/.libs/libgomp. so.1.0.0
/home/rintu/Galois/gcc-4.8.4/stage1-x86_64-unknown-linux- gnu/libgomp/.libs/libgomp.so
/home/rintu/Galois/gcc-4.8.4/stage1-x86_64-unknown-linux- gnu/libgomp/.libs/libgomp.so.1
/home/rintu/Galois/gcc-4.8.4/stage1-x86_64-unknown-linux- gnu/libgomp/.libs/libgomp.so. 1.0.0
/home/rintu/Galois/gcc-4.8.4/x86_64-unknown-linux-gnu/32/ libgomp/.libs/libgomp.so
/home/rintu/Galois/gcc-4.8.4/x86_64-unknown-linux-gnu/32/ libgomp/.libs/libgomp.so.1
/home/rintu/Galois/gcc-4.8.4/x86_64-unknown-linux-gnu/32/ libgomp/.libs/libgomp.so.1.0.0
/home/rintu/Galois/gcc-4.8.4/x86_64-unknown-linux-gnu/ libgomp/.libs/libgomp.so
/home/rintu/Galois/gcc-4.8.4/x86_64-unknown-linux-gnu/ libgomp/.libs/libgomp.so.1
/home/rintu/Galois/gcc-4.8.4/x86_64-unknown-linux-gnu/ libgomp/.libs/libgomp.so.1.0.0
/home/rintu/Galois/objdir/lib/libgomp.so
/home/rintu/Galois/objdir/lib/libgomp.so.1
/home/rintu/Galois/objdir/lib/libgomp.so.1.0.0
/home/rintu/Galois/objdir/lib64/libgomp.so
/home/rintu/Galois/objdir/lib64/libgomp.so.1
/home/rintu/Galois/objdir/lib64/libgomp.so.1.0.0
/opt/centos/devtoolset-1.1/root/usr/lib/gcc/x86_64- redhat-linux/4.7.2/libgomp.so
/opt/centos/devtoolset-1.1/root/usr/lib/gcc/x86_64- redhat-linux/4.7.2/32/libgomp. so
/opt/gcc-cilkplus-install/lib64/libgomp.so
/opt/gcc-cilkplus-install/lib64/libgomp.so.1
/opt/gcc-cilkplus-install/lib64/libgomp.so.1.0.0
/opt/rh/devtoolset-3/root/usr/lib/gcc/x86_64-redhat-linux/4. 9.2/libgomp.so
/opt/rh/devtoolset-3/root/usr/lib/gcc/x86_64-redhat-linux/4. 9.2/32/libgomp.so
/opt/rh/devtoolset-4/root/usr/lib/gcc/x86_64-redhat-linux/5. 2.1/libgomp.so
/opt/rh/devtoolset-4/root/usr/lib/gcc/x86_64-redhat-linux/5. 2.1/32/libgomp.so
/usr/lib/gcc/x86_64-redhat-linux/4.4.4/libgomp.so
/usr/lib/gcc/x86_64-redhat-linux/4.4.4/32/libgomp.so
/usr/lib64/libgomp.so.1
/usr/lib64/libgomp.so.1.0.0
I can't reproduce the issue on my system as well. I think a clean install of the compiler and a corresponding clean GNU distro won't show this issue. So, my assumption is if you don't need that which was installed by the previous user then you should do so and try it out.
This was an issue a few years ago with Intel openmp runtime https://software.intel.com/en-us/articles/gcc-49-openmp-code-cannot-be-linked-with-intel-openmp-runtime but that's not the case now with the latest releases.
Kittur
Hi Kittur, Mal. and Tim,
Thanks a lot.
Our pleasure, Amlesh. Thanks for using the product and bringing up issues to our attention.
Kittur.
