Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
7668 Discussions
Composer Update 6 bug with /MP switch
ILevi1
Valued Contributor I
I just submitted an issue (#647664) for a bug in composer_2011_update6.043 composer_12.1.0.043 and thought that it would be usefull to share it with others.
Namely, if you compile single source code file (.cpp) using:
icl /c /FAs /MPn where n > 0, compiler will try to assemble the .asm file even though /c (compile only) is specified, and fail to produce .obj as a result.
Milind_Kulkarni__Int
New Contributor II
hello,
the bug got fixed for the latest update 12.1 U3 ( 12.1.3.300) already. The compiler is available for download from registrationcenter.intel.com
I am closing this issue as Resolved.
Milind Kulkarni
