Intel® C++ Compiler
7876 Discussions
Configure to compile OpenMPI 4.1.1 on OSX
shyoo08
I have a problem to compile OpenMPI 4.1.1 by Intel Classic Compiler, which is included in Intel OneAPI HPC Toolkit 2021.4. Here is the command that I used.
./configure --prefix=/usr/local/opt/openmpi/4.1.1 CC=icc CXX=icpc CFLAGS='-isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk -L/opt/intel/oneapi/compiler/latest/mac/compiler/lib -I/opt/intel/oneapi/compiler/latest/mac/compiler/include'
When I used above command, I met an error below.
configure: error: ptrdiff_t type is not available, this is required by C99 standard.  Cannot continue
I found that 'stddef.h', which enveloped with ICC, has ptrdiff_t type definition.
(location is /opt/intel/oneapi/compiler/latest/mac/compiler/include/icc/stddef.h')
What should I do to resolve the problem?
SantoshY_Intel
We are able to reproduce your issue at our end. We are working on your issue internally and we will get back to you soon.
Thanks & Regards,
Santosh
shyoo08
Dear Santosh,
Thanks for your kind reply.
I will wait your test results.
Sincerely,
SangHyuk Yoo
Viet_H_Intel
I am not so sure what happened but I don't think it is compiler issue.
Looking at your provided config.log, I saw so many errors:
conftest.c(10): error #2379: cannot open source file "string.h"
 #include <string.h>
conftest.c(52): catastrophic error: cannot open source file "minix/config.h"
 #include <minix/config.h>
conftest.c(80): error #2379: cannot open source file "zlib.h"
 #include <zlib.h>
conftest.c(83): error: expected a ";"
    error: this is not __NetBSD__
Can you compile this test program to see if you still having issue with ptrdiff_t?
$ cat t2.c
#include <stdio.h>
#include <stddef.h>
int main()
  const int N = 50;
  int tmps[N];
  int *int1=&tmps[20], *int2=&tmps[24];
  ptrdiff_t diff_is = int2 - int1;
  printf("int2 - int1 = %td\n", diff_is);
  return 0;
$ icc t2.c &&./a.out
int2 - int1 = 4
shyoo08
Dear Viet
Thank you for your kind reply.
I have done your request.
Compiling 't2.c' make an error that icc cannot find the 'stdio.h'. This is because icc do not know the header file location.
icc t2.c
t2.c(1): catastrophic error: cannot open source file "stdio.h"
  #include <stdio.h>
For that reason, I used '-isysroot' command for compilation.
Here is the command, which was also used in compiling OpenMPI.
icc -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk t2.c
Since I introduced the header files directory to icc by '-isysroot' tag, 't2.c' was compiled and worked in Mac.
./a.out
int2 - int1 = 4
There is a page that give the solution when people stuck in use of icc in Mac .
https://community.intel.com/t5/Intel-C-Compiler/catastrophic-error-Cannot-open-source-file-quot-stdio-h-quot/m-p/1186099?profile.language=ko
Is there a problem to use '-isysroot'?
Sincerely,
SangHyuk Yoo
Viet_H_Intel
This is clearly there are some issues with your ENV, which icc couldn't find header files. I wonder if gcc does the same?
This is your original command line for compiling conftest.c
icc -c -O3 -DNDEBUG -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk -L/opt/intel/oneapi/compiler/latest/mac/compiler/lib -I/opt/intel/oneapi/compiler/latest/mac/compiler/include -std=gnu11 -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(175): error: identifier "ptrdiff_t" is undefined
 if (sizeof (ptrdiff_t))
What happens if you do:
icc -c -O3 -DNDEBUG -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk -L/opt/intel/oneapi/compiler/latest/mac/compiler/lib -I/opt/intel/oneapi/compiler/latest/mac/compiler/include -std=gnu11 -finline-functions -fno-strict-aliasing -restrict t2.c? Will it fail to compile?
shyoo08
Dear Viet,
Thanks for your fast reply.
I agree with your opinion.
I did search in google and I found that some people were suffering the same problem.
As you requested, I entered the command you gave me.
Mac did not give any error and objective file was made successfully.
I attached the screenshot of my terminal.
Sincerely,
SangHyuk Yoo
Viet_H_Intel
Ok, the same command line (used for conftest.c) worked on a simple test case. Could be that STDC_HEADERS isn't defined in your ENV, which then excluded stddef.h?
configure:21860: icc -c -O3 -DNDEBUG -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk -L/opt/intel/oneapi/compiler/latest/mac/compiler/lib -I/opt/intel/oneapi/compiler/latest/mac/compiler/include -std=gnu11 -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
compilation aborted for conftest.c (code 2)
configure:21860: $? = 2
configure: failed program was:
| /* confdefs.h */
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
One thing you can try is to go to the directory where conftest.c resides, then run "icc -c -O3 -DNDEBUG -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk -L/opt/intel/oneapi/compiler/latest/mac/compiler/lib -I/opt/intel/oneapi/compiler/latest/mac/compiler/include -std=gnu11 -finline-functions -fno-strict-aliasing -restrict conftest.c"
To see if you still get the same error on ptrdiff_t?
shyoo08
Dear Viet,
I have a problem. I cannot find the location of 'confides.h'.
I expect that the file resides in 'openmpi' directory, but it is not.
Did you know where is the file created during configuration?
Sincerely,
SangHyuk Yoo
Viet_H_Intel
I extracted it from your config.log
Viet_H_Intel
shyoo08
Dear Viet,
I tested the attached code, which was extracted from 'config.log'.
The terminal showed that the compiler cannot identify 'ptrdiff_t' type.
conftest.c(174): error: identifier "ptrdiff_t" is undefined
As you pointed out, STDC_HEADERS was not defined in my environment, so 'stddef.h' was not included in the 'contest.c'.
I will define STDC_HEADERS manually and try to compile 'openmpi'.
And then, I will report the result in this page.
Thanks Viet!
Sincerely,
SangHyuk Yoo
shyoo08
I tested with set up environment variable as below in zsh.
export STDC_HEADERS=1
However, I still get the same message that icc cannot find the type 'ptrdiff_d'.
Is there any suggestion?
Sincerely,
SangHyuk Yoo
Viet_H_Intel
How about adding -DSTDC_HEADERS to the command line?
icc -c -O3 -DNDEBUG -DSTDC_HEADERS  -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk -L/opt/intel/oneapi/compiler/latest/mac/compiler/lib -I/opt/intel/oneapi/compiler/latest/mac/compiler/include -std=gnu11 -finline-functions -fno-strict-aliasing -restrict conftest.c
shyoo08
Dear Viet,
As your suggestion, I did not meet the 'ptrdiff_t' problem. Thank you so much Viet.
Below command is that I used in macOS (BigSur 11.6). During configuration, CXXFLAGS are also required. Thus, I copy the CFLAGS.
./configure --prefix=/usr/local/opt/openmpi/4.1.1 CC=icc CXX=icpc CFLAGS='-isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk -L/opt/intel/oneapi/compiler/latest/mac/compiler/lib -I/opt/intel/oneapi/compiler/latest/mac/compiler/include -DSTDC_HEADERS' CXXFLAGS='-isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk -L/opt/intel/oneapi/compiler/latest/mac/compiler/lib -I/opt/intel/oneapi/compiler/latest/mac/compiler/include -DSTDC_HEADERS'
However, I faced another problem during making process.
It seems the c language grammar problem. Do you have any suggestion?
I think that I need to test older version of OpenMPI (e.g. 3.x.x).
make -j2
Making all in config
make[1]: Nothing to be done for `all'.
Making all in contrib
Making all in opal
Making all in include
/Library/Developer/CommandLineTools/usr/bin/make  all-am
Making all in datatype
  CC       libdatatype_reliable_la-opal_datatype_pack.lo
  CC       libdatatype_reliable_la-opal_datatype_unpack.lo
In file included from ../../opal/include/opal_config.h(3090),
                 from opal_datatype_unpack.c(25):
../../opal/include/opal_config_bottom.h(406): error: expected a ")"
  static inline uint32_t htonl(uint32_t hostvar) { return hostvar; }
../../opal/include/opal_config_bottom.h(406): warning #2171: declaration hides built-in function "__builtin_constant_p"
../../opal/include/opal_config_bottom.h(407): error: expected a ")"
  static inline uint32_t ntohl(uint32_t netvar) { return netvar; }
                 from opal_datatype_pack.c(24):
../../opal/include/opal_config_bottom.h(407): error: function "__builtin_constant_p" has already been defined
../../opal/include/opal_config_bottom.h(408): error: function "__builtin_constant_p" is not a type name
  static inline uint16_t htons(uint16_t hostvar) { return hostvar; }
../../opal/include/opal_config_bottom.h(408): error: expected a ")"
../../opal/include/opal_config_bottom.h(408): error: "__uint16_t" has already been declared in the current scope
../../opal/include/opal_config_bottom.h(408): error #141: unnamed prototyped parameters not allowed when body is present
../../opal/include/opal_config_bottom.h(408): error: identifier "hostvar" is undefined
../../opal/include/opal_config_bottom.h(409): error: function "__builtin_constant_p" is not a type name
  static inline uint16_t ntohs(uint16_t netvar) { return netvar; }
../../opal/include/opal_config_bottom.h(409): error: expected a ")"
../../opal/include/opal_config_bottom.h(409): error: function "__uint16_t" has already been defined
../../opal/include/opal_config_bottom.h(409): error #141: unnamed prototyped parameters not allowed when body is present
../../opal/include/opal_config_bottom.h(409): error: identifier "netvar" is undefined
compilation aborted for opal_datatype_pack.c (code 2)
compilation aborted for opal_datatype_unpack.c (code 2)
make[2]: *** [libdatatype_reliable_la-opal_datatype_pack.lo] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [libdatatype_reliable_la-opal_datatype_unpack.lo] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
Sincerely,
SangHyuk Yoo
Viet_H_Intel
Yes, seems like you have some other ENV issues. You may need to try with gcc/g++ first to see if it works then switch to icc/icpc
shyoo08
Dear Viet,
I'm sorry to reply late.
Before I tray to compile with icc, I have compiled with gcc/g++ and clang. At that time, I did not find any problem.
Sincerely,
SangHyuk Yoo
Viet_H_Intel
Thank for the input. We have seen that when your env setup correctly then icc worked. Thus, I am not sure how ./configure setting up the ENV, but even "string.h" could not be found in your config.log
 #include <string.h>
You may try to compare gcc's configure with icc's to see what are the differences.
Viet_H_Intel
Hi SangHyuk Yoo,
One thing we noticed that you are on BigSur 11.6, which isn't a supported OS in oneAPI 2021 Update 4.
https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/intel-compilers-compatibility-with-microsoft-visual-studio-and-xcode.html
Can you try on a supported OS to see if the problem still persists?
shyoo08
Dear Viet,
I'm sorry to reply late. I just moved so that I cannot test it right now.
Anyway, my OS is too latest version (OS X 11.6) to be supported by ICC.
If I can downgrade my OS version, I will try it.
Thank you very much for every help.
Sincerely,
SangHyuk Yoo
shyoo08
Dear Viet,
I tried to downgrade my OS version, but I failed to do it because of an unknown reason in my Macbook.
I should use OpenMPI with the default C compiler in Mac until ICC will support the current OS version.
I really appreciate your advice.
Sincerely,
SangHyuk Yoo
