I have a problem to compile OpenMPI 4.1.1 by Intel Classic Compiler, which is included in Intel OneAPI HPC Toolkit 2021.4. Here is the command that I used.
./configure --prefix=/usr/local/opt/openmpi/4.1.1 CC=icc CXX=icpc CFLAGS='-isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk -L/opt/intel/oneapi/compiler/latest/mac/compiler/lib -I/opt/intel/oneapi/compiler/latest/mac/compiler/include'
When I used above command, I met an error below.
configure: error: ptrdiff_t type is not available, this is required by C99 standard. Cannot continue
I found that 'stddef.h', which enveloped with ICC, has ptrdiff_t type definition.
(location is /opt/intel/oneapi/compiler/latest/mac/compiler/include/icc/stddef.h')
What should I do to resolve the problem?
- « Previous
- 1
- 2
- Next »
Yes, you should use the OS that the compiler listed as a supported versions.
We've released a oneAPI 2022.1. Can you see if this version solves your ENV issues?
Dear Viet,
Thank you very much for knowing the new versions.
I updated the oneAPI Toolkit and recompiled OpenMPI-4.1.1 manually.
I think that the ENV issues are resolved.
I appreciate yours helps again.
Sincerely,
SangHyuk Yoo
Since your ENV is resolved, we are closing this thread and will no longer monitor it. Please post a new question if you need any additional information.
- « Previous
- 1
- 2
- Next »
