I'm getting contradictory messages from the vectoriser in a number of places. These lines were sequential in the vectoriser report:
genselUtil.h(680) (col. 2): remark: loop was not vectorized: unsupported loop structure.
genselUtil.h(680) (col. 2): remark: LOOP WAS VECTORIZED.
Which is confusing to the user. I guess the question is whether this indicates the vectoriser is missing out on some potential vectorisations, is vectorising but reporting incorrectly or is correctly not vectorising some unsuitable code
David
David
It looks ambigous. It would be nice if you could help with suitable testcase to narrow down the issue.
The latest compilers often create several versions of the loop, including, according to this report, both vectorized and non-vectorized ones. opt-report should report the multi-versioning. Several months ago, I filed problem reports on some cases where the newly added non optimized versions are the ones which are actually found at run time. I suppose this is most likely to happen with nested loops, at -O3.
I should have said in the original email that this is on Linux at O2 with ICC 12.0
