I'm in process of converting from Microsoft Visual Studio 2008 to MSV2012 for my mixed code, C and FORTRAN application.
The code compiles and executes perfectly for MSV2008 but I receive many, many error messages for the C portion of my code
when I try to compile using MSV2012 wrapper.
The compiler does not like the line:
int _stdcall OPEN_MATLAB(name,ll)
The first couple of error messages are :
1>Source\matlab.c(38): error C2065: 'name' : undeclared identifier
1>Source\matlab.c(38): error C2065: 'll' : undeclared identifier
I've imported all the project properties from MSV2008 into MSV2012, and, I've compared all the compiler flags.
The flags appear to be the same in both MSV2008 and MSV2012. I'm guessing that MSV2012 needs to have some
compiler flag set, so that it is doing the same thing that MSV2008 was doing for me.
I'm a FORTRAN programmer that has inherited this C code (i.e. I don't know C very well). Any help would be greatly
appreciated.
Here's what the code looks like:
#include "stdio.h"
#include "string.h"
#define DATASIZE float
#define ISIZ int
typedef struct
ISIZ type;
ISIZ mrows;
ISIZ ncols;
ISIZ imagf;
ISIZ namlen;
ISIZ name;
}Fmatrix;
FILE *fp;
char name[];
int ll;
fp = fopen(name,"ab");
if (fp != NULL)
return(0);
else
return(1);
Did you set your project to use Intel C++ rather than Microsoft compiler in both cases? If you are using Microsoft C++ it may be difficult to get an answer here. Your question pertains to matlab so you may not find the right experts here.
If you are changing between 32- and 64-bit mode, you may need corresponding source code changes. _stdcall became obsolete 15 years ago.
