Why does the optimization crush the code so much it changes the outcome of the code and how can I stop it?
- « Previous
- 1
- 2
- Next »
I managed to get 21GB/s read and 19.3GB/s write with 2 arrays I think that must be as fast as a single thread can go:
#include <memory.h>
#include <ia32intrin.h>
unsigned long long* data0;
unsigned long long* data1;
bool Create(){
data0=new unsigned long long[67108864];
data1=new unsigned long long[67108864];
return true;
bool Destroy(){
delete[] data0;
delete[] data1;
return true;
bool Write(unsigned long long dval){
#pragma simd
for(long i=0;i<67108864;++i){data1=data0=dval;}
return true;
//volatile unsigned long long errxor;
bool Read(unsigned long long dval, unsigned long long errxor){
#pragma simd
for(long i=0;i<67108864;++i){errxor=errxor^data1^data0;}
return errxor!=dval;
Write disassembly:
vmovdqu xmmword ptr [ebx+eax*8],xmm0
vmovntdq xmmword ptr [ecx+eax*8],xmm0
add eax,2
cmp eax,edx
jb Write+50h (0FDA10A0h)
Read disassembly:
vpxor xmm0,xmm0,xmmword ptr [ebx+eax*8]
vpxor xmm1,xmm0,xmmword ptr [edx+eax*8]
vpxor xmm2,xmm1,xmmword ptr [ebx+eax*8+10h]
vpxor xmm3,xmm2,xmmword ptr [edx+eax*8+10h]
vpxor xmm4,xmm3,xmmword ptr [ebx+eax*8+20h]
vpxor xmm5,xmm4,xmmword ptr [edx+eax*8+20h]
vpxor xmm6,xmm5,xmmword ptr [ebx+eax*8+30h]
vpxor xmm0,xmm6,xmmword ptr [edx+eax*8+30h]
add eax,8
cmp eax,ecx
jb Read+47h (0FDA1127h)
Bandwidth analysis attached, Qparallel is off and loop unrolling is decided by the compiler, this is the code used:
#include <memory.h>
bool Create(){
return true;
bool Destroy(){
delete[] data0;
delete[] data1;
return true;
#pragma simd
//#pragma parallel
return true;
#pragma simd
//#pragma parallel
I still can't make the error checking work on the Read method please help.
Check this out I maxed out the Write speed at about 55GB/s by adding my own AVX intrinsics and enabling Qparallel:
bool Write(double dval){
__m256d ymm0=_mm256_set1_pd(dval);
#pragma parallel
for(long i=0;i<134217728;i+=4){
_mm256_store_pd(data0+i, ymm0);
return true;
and heres those big juicy ymm's!
inc ebx
vmovntpd ymmword ptr [edi+edx],ymm0
vmovntpd ymmword ptr [edi+edx+20h],ymm0
add edi,40h
cmp ebx,esi
jb Write+17Bh (0F2C11BBh)
It seems that you finally got real improvement in increasing memory speed of your test case.
I'm still having trouble with the Read method and error checking, how do I make this parallelizable(if that's even a word):
bool Read(double dval, double errxor){
double errxord[4]={errxor, errxor, errxor, errxor};
__m256d ymm0=_mm256_loadu_pd(errxord);
ymm0=_mm256_xor_pd(ymm0, _mm256_loadu_pd(data0+i));
if(ymm0.m256d_f64[0]!=dval||ymm0.m256d_f64[1]!=dval||ymm0.m256d_f64[2]!=dval||ymm0.m256d_f64[3]!=dval)return true; else return false;
OpenMP provides for xor reduction; if you don't like OpenMP, you will have to think about the analogy. Each thread does a private reduction, results combined at the end, probably in tree fashion if using a significant number of threads.
You could do parallelization over a for loop by giving to each thread iterate over the loop index.For example threadID 0 (i = 1<i =2n<arrayLen),threadID 1(i = 2<i = 2n<arrayLen),threadID 2 (i = 3<i =2n<arrayLen),threadID 4 (i = 4<i = 2n<arrayLen).The hardest part will be thread synchronisation.
Iv dumped the error checking now I just want the fastest way to read RAM, how do I do that?
This is what iv tried:
volatile __m256i ymm0=_mm256_set_epi64x(data0, data0[i+1], data0[i+2], data0[i+3]);
for(long i=0;i<134217728;++i){
volatile __int64 ptr=data0;
both of them read into then out of the register and I think thats whats slowing it down, why cant I just read memory without doing anything else?
Hey look I got the assembly from the memory read test loop in aida64, how do they do that?:
sub rsi,200h
movntdqa xmm0,xmmword ptr [rsi+170h]
movntdqa xmm1,xmmword ptr [rsi+160h]
movntdqa xmm2,xmmword ptr [rsi+150h]
movntdqa xmm3,xmmword ptr [rsi+140h]
movntdqa xmm4,xmmword ptr [rsi+130h]
movntdqa xmm5,xmmword ptr [rsi+120h]
movntdqa xmm6,xmmword ptr [rsi+110h]
movntdqa xmm7,xmmword ptr [rsi+100h]
movntdqa xmm8,xmmword ptr [rsi+0F0h]
movntdqa xmm9,xmmword ptr [rsi+0E0h]
movntdqa xmm10,xmmword ptr [rsi+0D0h]
movntdqa xmm11,xmmword ptr [rsi+0C0h]
movntdqa xmm12,xmmword ptr [rsi+0B0h]
movntdqa xmm13,xmmword ptr [rsi+0A0h]
movntdqa xmm14,xmmword ptr [rsi+90h]
movntdqa xmm15,xmmword ptr [rsi+80h]
movntdqa xmm0,xmmword ptr [rsi+70h]
movntdqa xmm1,xmmword ptr [rsi+60h]
movntdqa xmm2,xmmword ptr [rsi+50h]
movntdqa xmm3,xmmword ptr [rsi+40h]
movntdqa xmm4,xmmword ptr [rsi+30h]
movntdqa xmm5,xmmword ptr [rsi+20h]
movntdqa xmm6,xmmword ptr [rsi+10h]
movntdqa xmm7,xmmword ptr [rsi]
movntdqa xmm8,xmmword ptr [rsi-10h]
movntdqa xmm9,xmmword ptr [rsi-20h]
movntdqa xmm10,xmmword ptr [rsi-30h]
movntdqa xmm11,xmmword ptr [rsi-40h]
movntdqa xmm12,xmmword ptr [rsi-50h]
movntdqa xmm13,xmmword ptr [rsi-60h]
movntdqa xmm14,xmmword ptr [rsi-70h]
movntdqa xmm15,xmmword ptr [rsi-80h]
sub rsp,200h
jne 0000000000490180
I do not understand what you want to achieve.Do not use registers for memory transfer?
As I said in post #3 I just want to know how to benchmark RAM, it seems I will have to use inline assembly can you tell me how I can read and write RAM using inline AVX assembly without the optimization interfering or doing any sort of processing that will slow it down?
Code inside _asm{} block is not optimised.Compiler will probably add xmmword ptr or ymmword ptr to your code.You can write a set of simple SSE and AVX inline assembly based routines to read and write memory only.Allocate memory with _mm_malloc() aligned on 64 bytes and allocating memory in blocks of page size.For measuring speed of execution my favourite option is to use rdtsc intrinsic.
Btw. You could get a better answer on ISA forum by asking Dr. McCalpin.He is author of STREAM benchmark.
What do you mean by "allocating memory in blocks of page size"?
Post edited because I just realized my mistake I shouldn't have used "#pragma vector always".
Allocating memory in multiplies of page size (4KB).
- « Previous
- 1
- 2
- Next »
