Intel® C++ Compiler
Coverage fails due to an error message in profmerge
Volkan_G_
We are using intel's coverage tool for coverage tests and at the step where profmerge is called to generate DPI files from DYN, we get the following message:
*** glibc detected *** profmerge: double free or corruption (!prev): 0x0000000004a6d6d0 ***
======= Backtrace: =========
/lib64/libc.so.6(+0x78b66)[0x7f9953da2b66]
/lib64/libc.so.6(fclose+0x14d)[0x7f9953d9354d]
profmerge[0x44a106]
profmerge[0x405855]
profmerge[0x4024a1]
/lib64/libc.so.6(__libc_start_main+0xf5)[0x7f9953d4b455]
profmerge[0x40213a]
======= Memory map: ========
00400000-00530000 r-xp 00000000 08:11 15736839                           /home/soft/Intel/composer_xe_2011_sp1.7.256/bin/intel64/profmerge
00630000-006a0000 rw-p 00130000 08:11 15736839                           /home/soft/Intel/composer_xe_2011_sp1.7.256/bin/intel64/profmerge
006a0000-006ab000 rw-p 00000000 00:00 0
018d2000-0656c000 rw-p 00000000 00:00 0                                  [heap]
7f9953d2a000-7f9953ec5000 r-xp 00000000 08:01 1179709                    /lib64/libc-2.15.so
7f9953ec5000-7f99540c5000 ---p 0019b000 08:01 1179709                    /lib64/libc-2.15.so
7f99540c5000-7f99540c9000 r--p 0019b000 08:01 1179709                    /lib64/libc-2.15.so
7f99540c9000-7f99540cb000 rw-p 0019f000 08:01 1179709                    /lib64/libc-2.15.so
7f99540cb000-7f99540cf000 rw-p 00000000 00:00 0
7f99540cf000-7f99540e4000 r-xp 00000000 08:01 1179751                    /lib64/libgcc_s.so.1
7f99540e4000-7f99542e3000 ---p 00015000 08:01 1179751                    /lib64/libgcc_s.so.1
7f99542e3000-7f99542e4000 r--p 00014000 08:01 1179751                    /lib64/libgcc_s.so.1
7f99542e4000-7f99542e5000 rw-p 00015000 08:01 1179751                    /lib64/libgcc_s.so.1
7f99542e5000-7f99543cd000 r-xp 00000000 08:01 2756316                    /usr/lib64/libstdc++.so.6.0.17
7f99543cd000-7f99545cd000 ---p 000e8000 08:01 2756316                    /usr/lib64/libstdc++.so.6.0.17
7f99545cd000-7f99545d5000 r--p 000e8000 08:01 2756316                    /usr/lib64/libstdc++.so.6.0.17
7f99545d5000-7f99545d7000 rw-p 000f0000 08:01 2756316                    /usr/lib64/libstdc++.so.6.0.17
7f99545d7000-7f99545ec000 rw-p 00000000 00:00 0
7f99545ec000-7f99545ef000 r-xp 00000000 08:01 1179651                    /lib64/libdl-2.15.so
7f99545ef000-7f99547ee000 ---p 00003000 08:01 1179651                    /lib64/libdl-2.15.so
7f99547ee000-7f99547ef000 r--p 00002000 08:01 1179651                    /lib64/libdl-2.15.so
7f99547ef000-7f99547f0000 rw-p 00003000 08:01 1179651                    /lib64/libdl-2.15.so
7f99547f0000-7f99548e5000 r-xp 00000000 08:01 1179670                    /lib64/libm-2.15.so
7f99548e5000-7f9954ae5000 ---p 000f5000 08:01 1179670                    /lib64/libm-2.15.so
7f9954ae5000-7f9954ae6000 r--p 000f5000 08:01 1179670                    /lib64/libm-2.15.so
7f9954ae6000-7f9954ae7000 rw-p 000f6000 08:01 1179670                    /lib64/libm-2.15.so
7f9954ae7000-7f9954b08000 r-xp 00000000 08:01 1179934                    /lib64/ld-2.15.so
7f9954cdf000-7f9954ce5000 rw-p 00000000 00:00 0
7f9954d02000-7f9954d04000 rw-p 00000000 00:00 0
7f9954d04000-7f9954d07000 r--p 00000000 08:11 15861271                   /home/soft/Intel/composer_xe_2011_sp1.7.256/compiler/lib/intel64/locale/en_US/diagspt.cat
7f9954d07000-7f9954d08000 rw-p 00000000 00:00 0
7f9954d08000-7f9954d09000 r--p 00021000 08:01 1179934                    /lib64/ld-2.15.so
7f9954d09000-7f9954d0a000 rw-p 00022000 08:01 1179934                    /lib64/ld-2.15.so
7f9954d0a000-7f9954d0b000 rw-p 00000000 00:00 0
7fff7bb79000-7fff7bb9c000 rw-p 00000000 00:00 0                          [stack]
7fff7bbff000-7fff7bc00000 r-xp 00000000 00:00 0                          [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
Aborted
How can we solve this problem? We have approximately 450 dyn files.
Thank you.
Georg_Z_Intel
I've created an article for further information:
http://software.intel.com/en-us/articles/profmerge-fail-glibc-detected-profmerge-double-free-or-corruption
The ticket created for that is DPD200516926. Once fixed I'll update this thread.
Thank you for reporting & best regards,
Georg Zitzlsberger
Georg_Z_Intel
that's a little bit tricky to reproduce on our side because the merging depends on the DYN files.
I'd like to ask you to try to find a minimal subset of DYN files that still shows the exact problem. If you could then provide me a ZIP/TAR file with those DYN files would would help us to debug the problem in profmerge. Please send me a direct message via "Send author a message", so you don't disclose those files.
Please also let me know which OS you're using, whether it's 32 or 64 bit, and the exact Composer XE version.
Thank you in advance & best regards,
Georg Zitzlsberger
Volkan_G_
We have found the problem. After you said to minimize the DYN files to run profmerge, we found one of the DYN files had size of 0 bytes. Removing it solved the problem.
EDIT:
We are using openSUSE 12.2 64 bit with XE 12.1.0
Georg_Z_Intel
Georg Zitzlsberger
Georg_Z_Intel
Intel(R) Composer XE 2013 SP1 Update 3 (and later) will have a fix for the reported problem.
Georg Zitzlsberger
Volkan_G_
Thank you for solving this issue.
