Intel® C++ Compiler
Crash of latest 13 compiler on OSX 10.8
erling_andersen
I just installed the latest Intel 13 comipiler on MAC OSX but it crashes when run. Any suggestionswhat might be wrong?
Here the details:
lyngby:~ root# icc -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.0.3.198 Build 20130606
Copyright (C) 1985-2013 Intel Corporation. All rights reserved.
lyngby:~ root# cat test.c
int main()
return ( 1 );
lyngby:~ root# icc test.c -o test
Segmentation fault: 11
SergeyKostrov
Valued Contributor II
>>...Segmentation fault: 11 What compiler options did you use? Also, could you take a look at a MAC OSX API manual for a description of error code 11?
erling_andersen
As my example
  icc test.c -o test
all options are shown. This cause a segmentation fault and I assume the code 11 is related to that fault. From it is in my initial post you can do exactly what I did.
Maybe there something special about computer but it is a fairly new machine running OSX 10.8.
Casey
POSIX signal 11 is SIGSEGV, a.k.a segmentation fault a.k.a invalid memory reference.
erling_andersen
I do agree that the compiler must generate a segmentation fault. I have seen that on other systems when I run Intel C as nonroot the first time.
But in this case I run it as root. But guess no one has clue what the issue is then. It should work on OSX 10.8 I suppose?
erling_andersen
In fact when I run icc under gdb I get
(gdb) run test.c
Starting program: /usr/bin/icc test.c
Reading symbols for shared libraries ++++.................................. done
Program received signal EXC_BAD_ACCESS, Could not access memory.
Reason: KERN_INVALID_ADDRESS at address: 0x0000000000000000
0x000000010006caf9 in target_mac_requires_clang ()
(gdb)
Jeffrey_A_Intel
Can you post a reply with the output from these two commands?
xcodebuild -version
xcode-select -print-path
Brandon_H_Intel
Hi Erling,
I can't reproduce this. Jeff's questions are appropriate, so if you could answer those, that would be great. I'm following up with our driver developer as well to see if there's anything he can speculate further on.
erling_andersen
Now I know what the issue is. When I run
  xcodebuild -version
xcode asks me to accept some license agreements.  After I havde done that things works.
I never use the commandline version of xcode except when called from Intel.
I know it is an xcode stupidity you most likly do not detect but may you could.
Jeffrey_A_Intel
Thanks, Erling, for that information. That was what we thought might be happening after looking at the code pointed to by your gdb traceback.
Yes, the compiler will be modified to be to be more robust.
