I coded a multi-threading program that function very well when using microsoft c++ compiler.
But it crashes when changing to intel c++ compiler.
Handle hdl[5];
int idx=0;
The idx and hdl[5] are inited to 0 when the program starts.
Then the following function is called repeatly.
void function()
hdl[idx] = (HANDLE)_beginthreadex(0, 0, bthrd_dpcstub, pcur, 0, &thrdID);
printf("curr created handle %10x\\n", hdl[idx]);
idx++;
if(idx==5)
idx=0;
if(hdl[idx]!=0)
{printf("pre wait next handle %10x\\n", hdl[idx]);
WaitForSingleObject(hdl[idx], INFINITE);printf("aft wait next handle\\n");
CloseHandle(hdl[idx]);printf("aft close handle\\n");
hdl[idx] = 0;
It creates a new work thread and store it's handle to hdl[idx], then increment the idx to next idx.
then if the next hdl[idx] is with a working thread, wait for the end of the working thread and set the handle to 0.
The program runs fine with microsoft c++ compiler, but if I change to intel c++ compiler,
the results are following:
The handle of the created thread are as follows: 0x784, 0x788, 0x780, 0x77c, 0x778, 0x784
the next handle is as follows: 0, 0, 0, 0, 0x784, 0x788
It is all correct, but I found the program crashes on WaitForSingleObject(0x788, INFINITE), the created thread when the void function() is called in the second time, why? Is there some incompatibility between the two compiler?
Handle hdl[5];
int idx=0;
void function()
idx++;
if(idx==5)
idx=0;
if(hdl[idx]!=0)
hdl[idx] = 0;
