Greetings,
I figured that I'd try installing the new XE Composer 2016 on OS X 10.11 (beta 15A262e), even though it says it's only compatible with 10.10. It fails to even begin to install on two machines (a Mac Pro and a Macbook Pro). I'm using the full offline installer. Double clicking the app bundle just triggers a crash. Trying to start it via the command line by "./install_gui" produces a segmentation fault. Executing "sudo ./install_gui" brings up a splash screen followed by a warning dialog stating "Something is wrong with activation module...". See below for terminal output from "sudo ./install_gui". I also tried the online installer, with no success. The installer app runs and I get to the point where it asks to install as root or as administrator. If I try to install as administrator is simply says "Authorization failure. Check password and try again." However, it never prompts for a password. If I try to install as root, it does prompt me for a password, but I receive the same error.
Has anybody else tried to install using 10.11 with any success?
sudo ./install_gui
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 69: LI_WELCOME_PAGE_URL_daal.full=/documentation_2016/en/daal/ps2016/get_started.htm: No such file or directory
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 70: LI_WELCOME_PAGE_URL_ipp.full=/documentation_2016/en/ipp/common/get_started.htm: No such file or directory
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 71: LI_WELCOME_PAGE_URL_psxe.cproc=/documentation_2016/en/ps2016/startup_comp_mc.htm: No such file or directory
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 72: LI_WELCOME_PAGE_URL_psxe.cprof=/documentation_2016/en/ps2016/startup_comp_mf.htm: No such file or directory
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 73: LI_WELCOME_PAGE_URL_tbb.full=/documentation_2016/en/tbb/common/get_started.html: No such file or directory
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 195: LI_activation_notice_psxe.cproc=<font color='blue'><u>Warning:</u> Current customers should upgrade their license in either of the two ways:<br/>
- Re-enter your existing serial number.<br/>
- Obtain a new license file from Intel® Software Development Products Registration Center. See this <a href='https://software.intel.com/en-us/articles/required-license-upgrade-for-intel-system-studio-2016-and-intel-parallel-studio-xe-2016'>link</a> for details.</font>: No such file or directory
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 198: LI_activation_notice_psxe.cprof=<font color='blue'><u>Warning:</u> Current customers should upgrade their license in either of the two ways:<br/>
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 270: LI_banner_name_daal.full=Intel(R) Data Analytics Acceleration Library 2016 for OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 271: LI_banner_name_ipp.full=: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 272: LI_banner_name_psxe.cproc=Intel(R) Parallel Studio XE 2016 Composer Edition for C++ OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 273: LI_banner_name_psxe.cprof=Intel(R) Parallel Studio XE 2016 Composer Edition for Fortran OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 274: LI_banner_name_tbb.full=: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 460: LI_gdb.core.component_short_name=GNU* GDB 7.8: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 461: LI_gdb.core.description=GNU* GDB 7.8 (Provided under GNU General Public License v3): command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 462: LI_gdb.docs.component_short_name=Shared files for GNU GDB: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 463: LI_gdb.product_description=GNU* GDB components provided under GNU General Public License v3: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 464: LI_gdb.product_name=GNU* GDB: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 465: LI_gdb.python_src.component_short_name=Python sources: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 466: LI_gdb.python_src.description=Python sources (Provided under Python Software Foundation License): command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 467: LI_gdb.src.component_short_name=Source of GNU* GDB: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 468: LI_gdb.src.description=Source of GNU* GDB (Provided under GNU General Public License v3): command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 612: LI_product_name_daal.full=Intel(R) Data Analytics Acceleration Library 2016 for OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 613: LI_product_name_ipp.full=Intel(R) Integrated Performance Primitives 9.0 for OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 614: LI_product_name_psxe.cproc=Intel(R) Parallel Studio XE 2016 Composer Edition for C++ OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 615: LI_product_name_psxe.cprof=Intel(R) Parallel Studio XE 2016 Composer Edition for Fortran OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 616: LI_product_name_tbb.full=Intel(R) Threading Building Blocks 4.4 for OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 715: LI_welcome_title_text_daal.full=This application lets you:
- Evaluate or activate your product.: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 719: LI_welcome_title_text_ipp.full=This application lets you:
- Customize the installation of components in the product.
You can install all or just select the components you want.: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 731: LI_welcome_title_text_psxe.cproc=This application lets you:
Includes:
Intel(R) C++ Compiler 16.0
Intel(R) Math Kernel Library 11.3
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 741: LI_welcome_title_text_psxe.cprof=This application lets you:
Includes:
Intel(R) Fortran Compiler 16.0
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 743: LI_welcome_title_text_tbb.full=This application lets you:
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 75: LI_WELCOME_PAGE_URL_daal.full=/documentation_2016/en/daal/ps2016/get_started.htm: No such file or directory
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 76: LI_WELCOME_PAGE_URL_ipp.full=/documentation_2016/en/ipp/common/get_started.htm: No such file or directory
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 77: LI_WELCOME_PAGE_URL_psxe.cproc=/documentation_2016/en/ps2016/startup_comp_mc.htm: No such file or directory
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 78: LI_WELCOME_PAGE_URL_psxe.cprof=/documentation_2016/en/ps2016/startup_comp_mf.htm: No such file or directory
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 79: LI_WELCOME_PAGE_URL_tbb.full=/documentation_2016/en/tbb/common/get_started.html: No such file or directory
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 201: LI_activation_notice_psxe.cproc=<font color='blue'><u>Warning:</u> Current customers should upgrade their license in either of the two ways:<br/>
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 204: LI_activation_notice_psxe.cprof=<font color='blue'><u>Warning:</u> Current customers should upgrade their license in either of the two ways:<br/>
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 273: LI_banner_name_daal.full=Intel(R) Data Analytics Acceleration Library 2016 for OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 274: LI_banner_name_ipp.full=: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 275: LI_banner_name_psxe.cproc=Intel(R) Parallel Studio XE 2016 Composer Edition for C++ OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 276: LI_banner_name_psxe.cprof=Intel(R) Parallel Studio XE 2016 Composer Edition for Fortran OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 277: LI_banner_name_tbb.full=: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 467: LI_gdb.core.component_short_name=GNU* GDB 7.8: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 468: LI_gdb.core.description=GNU* GDB 7.8 (Provided under GNU General Public License v3): command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 469: LI_gdb.docs.component_short_name=Shared files for GNU GDB: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 470: LI_gdb.product_description=GNU* GDB components provided under GNU General Public License v3: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 471: LI_gdb.product_name=GNU* GDB: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 472: LI_gdb.python_src.component_short_name=Python sources: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 473: LI_gdb.python_src.description=Python sources (Provided under Python Software Foundation License): command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 474: LI_gdb.src.component_short_name=Source of GNU* GDB: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 475: LI_gdb.src.description=Source of GNU* GDB (Provided under GNU General Public License v3): command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 620: LI_product_name_daal.full=Intel(R) Data Analytics Acceleration Library 2016 for OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 621: LI_product_name_ipp.full=Intel(R) Integrated Performance Primitives 9.0 for OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 622: LI_product_name_psxe.cproc=Intel(R) Parallel Studio XE 2016 Composer Edition for C++ OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 623: LI_product_name_psxe.cprof=Intel(R) Parallel Studio XE 2016 Composer Edition for Fortran OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 624: LI_product_name_tbb.full=Intel(R) Threading Building Blocks 4.4 for OS X*: command not found
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 746: LI_welcome_title_text_daal.full=This application lets you:
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 750: LI_welcome_title_text_ipp.full=This application lets you:
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 762: LI_welcome_title_text_psxe.cproc=This application lets you:
Includes:
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 772: LI_welcome_title_text_psxe.cprof=This application lets you:
Includes:
/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_init: line 774: LI_welcome_title_text_tbb.full=This application lets you:
bash: line 1: 64556 Segmentation fault: 11 "/Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./install_gui" --__dumpenv__ > /Users/ryan/Desktop/m_ccompxe_2016.0.033.app/Contents/MacOS/./../..//tmp/shellexec_output
This is a bug. It's been reported as DPD200375931.
Although the beta OS is not supported, it shouldn't crash. Will update you when there is any progress.
thanks for letting us know.
Jennifer
