In MacOSX, gcc command line accepts multiarchitecture options:
gcc -arch i386 -arch x86_64 etc.
... and creates a universal binary by compiling and linking for both archs and running lipo for gluing them together.
However using this command line with Intel, produces a compiler warning:
command line warning #10121: overriding '-arch i386' with '-arch x86_64'
The other option is to perform all 3 steps on my own, however since I'm using cmake - that forces an awkward workaround.
Am I doing something wrong or is this a compiler limitation?
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
The compiler doesn't support 32bit compatibility in an x86_64 build. You would use the compiler targeting 32bit mode, which will run well on x86_64. If you really wish to target i386, Intel calls it ia32, but I doubt you would find a use for it. You can choose to support older cpu such as sse3 and also include optimization for a newer one such as avx.
Have you considered building two dynamic libraries (one 32-bit, the other 64-bit) then have a dual architecture stub program load and call the appropriate dynamic library?
Jim Dempsey
Jim, as stated in my original post, I could manually do it - however I was hoping that it could work as easy as gcc works.
Gil.
Intel Compiler 18.0 documentation clearly says you should build separate 32-bit and 64-bit binaries and combine them in a fat one
