I have question in mind and have tested that with GCC without success. So, I would like to know if it is *indeed* possible to do that with GCC or ICC. Actually the question is about machine instructions fetched by CPU.
I have written an assembly byte (0x00) as a code inside the main function. But after the compilation, according to the GDB, the 00 opcode is followed by the next instructions. In other words, the compiler (or gdb, I don't know) assumes that 00 is the add instructions so, it automatically appends other byte sequences to that. I don't want that!
(gdb) set disassembly-flavor intel (gdb) list 1 void main() 2 { 3 __asm__(".byte 0x00"); 4 } (gdb) disass /r main Dump of assembler code for function main: 0x00000000004004ed <+0>: 55 push rbp 0x00000000004004ee <+1>: 48 89 e5 mov rbp,rsp 0x00000000004004f1 <+4>: 00 5d c3 add BYTE PTR [rbp-0x3d],bl End of assembler dump.
So, I want to see
0x00000000004004ed <+0>: 55 push rbp 0x00000000004004ee <+1>: 48 89 e5 mov rbp,rsp ==========> 00 SOMETHING 0x00000000004004f1 <+4>: 5d pop rbp 0x00000000004004f2 <+5>: c3 ret
Actually I want to get an invalid opcode exception by the processor itself and not segmentation fault raised by software.
Any comment? Can i accomplish that with ICC?
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
- « Previous
- 1
- 2
- Next »
No, you should not insert __asm__ to generate invalid instruction sequences. You got what you asked the compiler to generate.
I think that is the only way to generate machine code directly as far as I know. That means, I was in the wrong direction for my investigations. From what I have read from Chris Domas experiments on unknown opcodes, it *is* possible to give a random sequence of 15-bytes (15 is the maximum length) and observe 1) the instructions length and 2) if it is valid/invalid instruction.
Do you mean I have to use an assembler, e.g NASM, instead of a compiler?
No. The __asm__ statement will do.
Keep in mind that invalid instruction sequences on CPU x may become valid on CPU y.
For example the REPxx prefixes being use on formerly undefined instructions for the RTM XACQUIRE/XRELEASE.
If you have a compiler that does not support XACQUIRE/XRELEASE but your CPU does support those instructions, then you could use the __asm__ to incorporate these into your program. That is one example.
Jim Dempsey
- « Previous
- 1
- 2
- Next »
