Intel® C++ Compiler
7956 Discussions
DEFINE_GUIDSTRUCT Gives "Error : type name is not allowed" In version 12
vetroxl
Using DEFINE_GUIDSTRUCT under Visual Studio 2010 and version 12 of the Intel C++ compiler gives the following error"Error : type name is not allowed"
Judith_W_Intel
I think I have come up with a reproducer for your problem.
This compiles fine with Microsoft, but broke in our 12.0 release:
void f() {
struct __declspec(uuid("00000000-0000-0000-0000-000000000000")) foo;
We will fix this as soon as possible. I have entered it into our bug tracking database as DPD200161827.
The problem is a disambiguation issue between declarations and expressions.
In the meantime, some possible workarounds are:
(1) Change
DEFINE_GUIDSTRUCT(__SOME_GUID__STRING__, SOME_TYPE_FOO_PROPSET);
to:
typedef DEFINE_GUIDSTRUCT(__SOME_GUID__STRING__, SOME_TYPE_FOO_PROPSET) SOME_TYPE_FOO_PROPSET;
(2) Or move this declaration:
to someplace outside of the function (not sure if it's necessary for it to be different in each case label?)
Judy
TimP
You'd likely have to look at the pre-processed code and show an actual example here before anyone could comment further.
Om_S_Intel
We may able to help better if you could share the test case.
vetroxl
Sure, this is coming from a third party. So I can't really change the code. Also note that it compiled fine under version 11.060.
[cpp]switch (_some_type_)
case _some_type_foo:
#define SOME_TYPE_FOO_PROPSET DEFINE_GUIDNAMED(SOME_TYPE_FOO_PROPSET)
				_GUID_PROPSET = SOME_TYPE_FOO_PROPSET;
break;
}[/cpp]
Mark_S_Intel1
Could you please compile the file in question with the "/P" option and send us the resulting .i file along with full compilation options used to compile the file?
--mark
Judith_W_Intel
void f() {
(1) Change
to:
Judy
vetroxl
Thanks, that works for now.
Judith_W_Intel
we've fixed this in our 12.0 development compiler, so you should see a fix in the next 12.0 update.
thanks for bringing this to our attention.
Judy
Mark_S_Intel1
This problem has been resolved in IntelC++ Composer XE update 1 (package ID w_ccompxe_2011.1.127.exe) available for download at registrationcenter.intel.com.
