I'm trying to install the C++ Composer xe on debian 6.0, but the version supported by C++ Composer is the Debian 5.0. Is it possible to do another thing without installing the old version of Debian?Thanks,
Alex.
You can install Intel compiler in Debian 6.0 as unspported OS. The compiler should work.
Hi
Working perfectly, is sure 100% with O/S 32 and 64 Debian 6 ,
(also with or without the last updates online added)
hi, if don't run good how you want, you can to install wine and install is as if you be executed in windows...
