Intel® C++ Compiler
7838 Discussions
Debian Buster - can't compile simple program
tepfer__michael
I was able to install it but I can't compile a simple hello world program.
$ ls
test.cpp
$ cat test.cpp
#include <iostream>
int main() {
	std::cout << "Hello world" << std::endl;
	return 0;
$ icpc test.cpp
In file included from test.cpp(1):
/usr/include/c++/8/iostream(38): catastrophic error: cannot open source file "bits/c++config.h"
  #include <bits/c++config.h>
compilation aborted for test.cpp (code 4)
$ icpc -v
icpc version 19.0.1.144 (gcc version 8.2.0 compatibility)
$ gcc -v
Using built-in specs.
COLLECT_GCC=/usr/bin/gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/8/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian 8.2.0-16' --with-bugurl=file:///usr/share/doc/gcc-8/README.Bugs --enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-8 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-libmpx --enable-plugin --enable-default-pie --with-system-zlib --with-target-system-zlib --enable-objc-gc=auto --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 8.2.0 (Debian 8.2.0-16)
Viet_H_Intel
Seems like c++config.h could not be found on your system.
