Intel® C++ Compiler
Debug a code by Eclipse
mhadian
I have installed Intel C++ compiler integrated with Eclipse on a Linux system.
1. Though i have installed idb, i can not find the option to debug the code using idb in Eclipse.
2. when i debug the code in Eclipse, the items for debugging line by line and debugging to a spesific line are always off.
does anybody know how to configure the Eclipse to overcome the above problems?
Hadian
William_H_Intel3
The idb debugger is not integrated with Eclipse except in the 9.1 product currently in beta test. If you are using 9.0 or 8.1, you can use gdb in Eclipse. Which version Intel compiler product are you using?
Bill
mhadian
mine is Intel C++ Compiler for Linux* v9.0
Build id: 20050421
and integrated with Eclipse Platform Version: 3.0.1
Build id: 200409161125
how can i debug the code by gdb in it "line by line"?
William_H_Intel3
You need to create a debug launch configuration. For details of how to do this, follow these steps in Eclipse. Open Help > Help Contents and expand the C++ Development User's Guide. In the User's Guide expand "Tasks" then "Running and Debugging Projects". Here you should see "Creating or Editing a run/debug configuration".
Hope that helps...Bill
