I am using Intel C++ compiler v15.0 on 64-bit Linux, and I have encountered what appears to be a very annoying bug in icpc. Depending on the order in which input files are passed to icpc, the compiler sometimes outputs bad DWARF debug info, which crashes the debugger. I tickled the bug while working with OpenCV 3.0, but someone on Stack Overflow also encountered it and posted a SSCCE. I have further refined the example and attached it as a ZIP file.
Steps to reproduce:
- Unzip attached sources
- run make
- debug resulting binaries
Expected output:
- Both binaries can be debugged with either gdb or gdb-ia
Actual output:
- debugging Test_good works, but
- debigging Test_bad with either gdb or gdb-ia results in debugger crash:
Reading symbols from ./Test_bad.../build/buildd/gdb-7.7.1/gdb/dwarf2read.c:19061: internal-error: follow_die_offset: Assertion `dwarf2_per_objfile->reading_partial_symbols' failed.
Other considerations:
- Using g++ (replace `icpc` wich `g++` in Makefile) produces debuggable binaries
- For each binary (Test_good/Test_bad) and compiler (icpc/g++), gdb and gdb-ia both exhibit the same behavior. Combined with the previous point, I think this heavily suggests icpc as the culprit.
- Between myself and the Stack Overflow post I linked above, this bug has been reproduced on the following systems:
Linux Mint 17.1 (based on Ubuntu 14.04), 64-bit
icpc version 15.0.0
gdb-ia version 7.7-8.0.524
gdb version 7.7.1
g++ version 4.8.2
OpenSUSE 12.3 64bit
icpc version 15.0.1
gdb version 7.5.1-2.1.1
gdb version 7.8.1
g++ version 4.7.2
In case it's not obvious from the included Makefile, the only difference between the Test_good and Test_bad binaries is the order in which input files are passed in. ie
icpc -std=c++11 -o Test_bad main.o D.o E.o B.o
vs
icpc -std=c++11 -o Test_good B.o D.o E.o main.o
Interesting coincidence is that I hit this exact same bug today. I discovered that if I used `strip` on the binary first, or compiled without the `-g` option, then I would not get the gdb crash. Of course, debugging without symbols is largely useless. :)
I'm using an older version of icpc (14) so it does not appear that the bug has been fixed in version 15 yet. I used gdb 7.5-1.3.187
I can reproduce this issue with gdb-ia (7.7-8.0.653), but my default gdb works (7.2-56.el6), I assume it may be something related to GDB version too.
I'll submit it to dev team to check more details.
Shenghong
According to the developer, there are no issues in the debug information.
This issue may also be related to GDB (possibly GDB bug). It works with gdb 7.9, could you please try?
Shenghong
I have confirmed that the following versions of gdb fail:
gdb 7.6.-47.el6
gdb 7.6.1-51.el7
gdb-ia 7.5-1.0.81
The following version works
gdb 7.9
-Mark
Hi Mark,
Thank you for your confirmation, it is same results as our developer's testing results and it seems to be a GDB bug (older and newer GDB works, only several GDB versions broken).
The issue is now escalated to gdb-ia (GDB provided in Intel Parallel Studio) team.
Shenghong
FYI. This issue was fixed in v16.0 initial release and 2015 U3 also. The fix means, we shipped a working gdb-ia in Parallel Studio now.
Shenghong
