Please recommend me a good debugger for c++
Hi Ramith,
You may post your issue on https://software.intel.com/en-us/forums/debug-solutions for better answers, but I will give some of my understandings...
First of all, your question is hard to give a solid answer, as it really depends on what kind of debug you want, and what kind of environment you work on, and what kind of working style you like (cmd or GUI) etc.
On Linux:
For some low level debugging, like the Linux kernel or driver, you may need something like "JTAG debugger", Intel has some JTAG debugger solutions provided.
For application level debugging, I guess GDB is the most popular. GDB itself is command line, but there are some GUI front-end, like using GDB in Eclipse. Also, GDB support remote debugging if you work on embedded Linux.
Intel provides a friendly GUI debugger named "IDB" but that was deprecated and not provided in Parallel Studio 2015 product. Instead, Intel now ships a enhanced GDB, which has some added features in GDB, like the data race detection feature.
On windows, I guess Visual Studio's in-built debugger is enough for most users. But there are some other famous debuggers like WinDgb, which supports kernel debugger too.
Hope it is helpful for you, and I am sure you need more exploration to get the debugger you really need, based on your requirements. It is hard to say which debugger is good and another one is bad. :)
Shenghong
Hi Ramith,
On Linux:
Shenghong
In addition to those mentioned there are commercial debuggers with additional capability for parallel programming such as allinea and totalview.
On Windows for system wide debugging you can use windbg and for C++ debugging during the development phase VS debugger will suit your needs.
BTW, Tim's comment on debugging for parallel programming reminded me to also let you know that there are other Intel products like Intel Inspector XE 2015 (which a developer can use to identify and resolve memory and threading issues in their c/c++ code) and Intel Vtune Amplifier XE 2015 (which a developer can use for performance analysis) as well that will come in handy. For this and other related product details you can visit the site at: https://software.intel.com/en-us/intel-sdp-home where you can find several interesting developer products as well .
_Kittur
> c++ for mainly programming problems.
Ramith, can you let us know what domain you do program in? Is it in a high level application domain (Linux or Android or Mac)? And do you also program in the embedded domain and interested in power analysis, JTAG debugging and so on as well? Thanks
_Kittur
I know you are doing algorithmic programming, so you are fine with GDB
