Intel® C++ Compiler
Default constructor of variant is deleted ?
Harris__John
icpc (ICC) 19.0.0.117 20180804
This works in g++ but not icpc with the same runtime library includes.
icpc -std=c++17 -c /tmp/t.cpp -o /tmp/t.o
#include <variant>
void foo();
void foo()
  std::variant<std::monostate, int> bar;
Gives:
/tmp/t.cpp(7): error: the default constructor of "std::variant<std::monostate, int>" cannot be referenced -- it is a deleted function
According to cppreference, the default constructor "Constructs a variant holding the
value-initialized value of the first alternative (index() is zero). This constructor
is constexpr if and only if the value initialization of the alternative type T_0 would
satisfy the requirements for a constexpr function. This overload only participates in
overload resolution if std::is_default_constructible_v<T_0> is true."
Viet_H_Intel
Let me look into it and will get back to you.
Viet
Viet_H_Intel
I have reported this to our Developer. Case number is CMPLRLIBS-2742
Harris__John
I had a workaround, but now I get an internal compiler error in Update 1 (2019.1.144):
#include <variant>
int main()
  using var_t = std::variant<std::monostate, int>;
  struct Workaround : var_t
    Workaround() : var_t(std::in_place_type<std::monostate>)
  Workaround myvar;
  return 0;
/opt/intel/compilers_and_libraries_2019.1.144/linux/bin/intel64/icpc    -g   -std=gnu++17 -o CMakeFiles/tmpproject.dir/__/main.cpp.o -c /home/jharris/tmp/tmpproject/main.cpp
/home/jharris/tmp/tmpproject/main.cpp(10): internal error: assertion failed at: "shared/cfe/edgcpfe/class_decl.c", line 3662
Viet_H_Intel
Thanks for reporting it. This seems to be a known issue. We have a bug number cmplril0-30500 to track it.
Viet
JonMc
Was this bug ever fixed?  We were just hit by it, and want to know what's the earliest version with a fix.
