I think here is another bug in the Intel Compiler XE 2014, SP1 Update 1 on Windows. Consider the following piece of code:
[cpp]
struct X
~X() { };
int main()
X x;
static_assert(noexcept(x.~X()), "Ouch!");
[/cpp]
This doesn't compile with Intel on Windows but it compiles fine using gcc 4.8.2 and CLang 3.4 on Linux. Moreover an answer on stackoverflow suggests that this should actually compile: http://stackoverflow.com/questions/15721544/destructors-and-noexcept
Cheers,
Raffael
Have reprocuded as you said ,I will enter this into bug-tracking system and will get you posted on any progress on this .Thank you for your issue submission.
Thank you.
QIAOMIN.Q
Intel Developer Support
Please participate in our redesigned community support web site:
User forums: http://software.intel.com/en-us/forums/
This will not be fixed since Mircosoft VS2013 doesn't support noexcept yet.
On Windows, the default is not to have implicit noexcept. On Linux, a fix has been added to enable this default in g++ 4.8 and later versions. So this is fine on Linux.
Thank you.
QIAOMIN.Q
