On Windows XP Pro x64 running on Q6600 this has 4 cores and from my understanding this is constructes as two pairs of cores with each pair of cores containing a 4MB L2 cache. I am calling GetLogicalProcessorInformation, I can see the 4 cores however the table returned seems to imply all 4 cores (1111) are sharing one 4MB L2 cache as opposed to two pairs of processors (0011) and (1100) each pair sharing a4MB L2 (i.e. 2 x 4MB L2).
What is the proper way to ascertain the relationship betweens cores and caches?
This may be a bug in the VS 2005 runtime libraries.
Jim Dempsey
Now I can get the number of L2 caches. Ihad to write an ASM routine (MSVC x64 cannot perform inline assembly)
void __cpuidEX(int CPUinfo[4], int eax, int ecx);
Such that I could get the Deterministic Cache Parameters and now I can see that I have two L2 caches.
However...
The information provided does not indicate which cores share which L2 caches.
Does someone know how to make that determination (without running a timing test)
I know the system thread affinity bit mask is _loosly_ associated to the packages.
I wish to write a routine to determine if L2 caches are shared by affinity (0/1, 2/3) or (0/2, 1/3).
Jim Dempsey
Thanks for the links, I am waiting for the reply email from MS now.
Why MS keys the download to the machine you use to access the KB downloads I will never know. The computer I generally use for browsing and emailing is a 32-bit WinXP system and I could not get to the x64 download from that computer. I had to perform the Windows Explorer fromt he x64 system (which exposes it to the internet, which I would rather not do).
Also I will check the new CPUID leaf.
My basic interest is to write a function to determine which processor affinities share which levels of cache (through to and includingNUMA nodes).
The reason why those downloads are keyed is so that the bad guys using pirated Windows copies couldn't get them (which of course doesn't work because the downloads can still be found on the Internet).
If you are trying to write such a function for the sake of optimal thread scheduling, you might want to take a look at the Thread Building Blocks librarybecause I heard it already takes careofthat for you and it comes with the Professional version of the compiler anyway. These days reinventing the wheel isn't so popular anymore ;-)
