Intel® C++ Compiler
7875 Discussions
Differences between classic C++ and DP C++ compiler
Ian_Chivers
I have a follow up to the previous post. the following example compiles and runs to completion using the classic compiler.
Here are the source files.
Main driving program
The following defines are required by the Intel compiler
#define and &&
#define not !
#define or ||
#include <execution>
#include <iostream>
#include <algorithm>
#include <vector>
#include <random>
#include <string>
#include <chrono>
#include <boost/sort/sort.hpp>
using namespace std;
using namespace boost::sort;
#include "timer.cxx"
#include "print_time.cxx"
// #include "swap.cxx"
// #include "quicksort.cxx"
// #include "print_10.cxx"
int main()
unsigned seed = std::chrono::system_clock::now().time_since_epoch().count();
default_random_engine engine_01(seed);
uniform_real_distribution<double>
distribution_01(0.0, 1.0);
string heading;
double t;
timer timer_01;
timer timer_02;
heading = "Program starts";
t = timer_01.elapsed();
print_time(heading, t);
timer_01.reset();
// Size
const int mega_byte = 1024 * 1024;
const int array_size = 128 * mega_byte;
int i;
vector<double> x(array_size);
cout << "\n C++ standard <vector> \n" << endl;
cout.width(16);
cout << array_size << endl;
cout.width(16);
cout << (array_size * 8);
cout << " bytes " << endl;
for (i = 0; i < array_size; i++)
x[i] = distribution_01(engine_01);
heading = "Random numbers";
timer_01.reset();
boost::sort::parallel_stable_sort(x.begin(), x.end());
heading = "Boost sort";
timer_01.reset();
heading = "Total time";
t = timer_02.elapsed();
return(0);
timer.cxx
#include <chrono>
class timer
public:
timer() : start_timing(hi_res_clock::now()) {}
void reset()
start_timing = hi_res_clock::now();
double elapsed() const
return(std::chrono::duration_cast<second_>
(hi_res_clock::now() - start_timing).count());
private:
typedef std::chrono::high_resolution_clock hi_res_clock;
typedef std::chrono::duration<double, std::ratio<1> >
second_;
std::chrono::time_point<hi_res_clock> start_timing;
print_time.cxx
void print_time(const string & heading, const double & t)
int nb=32;
int l = heading.length();
int i;
cout << heading << " : ";
for (i=1;i<nb-l;i++) cout << " ";
cout.setf(ios::right);
cout.setf(ios::showpoint);
cout.setf(ios::fixed);
cout.width(10);
cout.precision(6);
cout << t << endl;
Here is the classic output.
C:\document\cpp\examples>ch3806_intel_classic.exe
Program starts : 0.000000
134217728
1073741824 bytes
Random numbers : 0.930613
Boost sort : 1.671356
Total time : 2.605182
Using the replacement Intel compiler I get
the following compilation error messages.
C:\document\cpp\examples>icx /EHsc /nologo /F4294967295 /I "c:\local\boost_1_80_0" /O2 /Qstd=c++20 ch3806.cxx -o ch3806_intel_new.exe
In file included from ch3806.cxx:12:
In file included from c:\local\boost_1_80_0\boost/sort/sort.hpp:22:
c:\local\boost_1_80_0\boost/sort/parallel_stable_sort/parallel_stable_sort.hpp(160,16): error: no member named 'get_temporary_buffer' in namespace 'std'
ptr = std::get_temporary_buffer<value_t>(nptr).first;
c:\local\boost_1_80_0\boost/sort/parallel_stable_sort/parallel_stable_sort.hpp(236,5): note: in instantiation of member function
'boost::sort::stable_detail::parallel_stable_sort<std::_Vector_iterator<std::_Vector_val<std::_Simple_types<double>>>, std::less<double>>::parallel_stable_sort' requested here
stable_detail::parallel_stable_sort<Iter_t, Compare>(first, last);
ch3806.cxx(66,16): note: in instantiation of function template specialization 'boost::sort::parallel_stable_sort<std::_Vector_iterator<std::_Vector_val<std::_Simple_types<double>>>>' requested here
c:\local\boost_1_80_0\boost/sort/parallel_stable_sort/parallel_stable_sort.hpp(160,37): error: unexpected type name 'value_t': expected expression
c:\local\boost_1_80_0\boost/sort/parallel_stable_sort/parallel_stable_sort.hpp(160,51): error: member reference base type 'size_t' (aka 'unsigned long long') is not a structure or union
In file included from c:\local\boost_1_80_0\boost/sort/sort.hpp:17:
c:\local\boost_1_80_0\boost/sort/spinsort/spinsort.hpp(480,20): error: no member named 'get_temporary_buffer' in namespace 'std'
c:\local\boost_1_80_0\boost/sort/parallel_stable_sort/parallel_stable_sort.hpp(136,9): note: in instantiation of member function
'boost::sort::spin_detail::spinsort<std::_Vector_iterator<std::_Vector_val<std::_Simple_types<double>>>, std::less<double>>::spinsort' requested here
bss::spinsort<Iter_t, Compare>
c:\local\boost_1_80_0\boost/sort/parallel_stable_sort/parallel_stable_sort.hpp(70,7): note: in instantiation of member function
: parallel_stable_sort (first, last, Compare(),
c:\local\boost_1_80_0\boost/sort/spinsort/spinsort.hpp(480,41): error: unexpected type name 'value_t': expected expression
c:\local\boost_1_80_0\boost/sort/spinsort/spinsort.hpp(480,55): error: member reference base type 'size_t' (aka 'unsigned long long') is not a structure or union
c:\local\boost_1_80_0\boost/sort/spinsort/spinsort.hpp(419,44): error: no type named 'return_temporary_buffer' in namespace 'std'
if (owner and ptr != nullptr) std::return_temporary_buffer(ptr);
In file included from c:\local\boost_1_80_0\boost/sort/sort.hpp:21:
c:\local\boost_1_80_0\boost/sort/sample_sort/sample_sort.hpp(291,29): error: no member named 'get_temporary_buffer' in namespace 'std'
value_t *ptr = std::get_temporary_buffer<value_t>(nelem).first;
c:\local\boost_1_80_0\boost/sort/parallel_stable_sort/parallel_stable_sort.hpp(174,9): note: in instantiation of member function
'boost::sort::sample_detail::sample_sort<std::_Vector_iterator<std::_Vector_val<std::_Simple_types<double>>>, std::less<double>>::sample_sort' requested here
sample_sort<Iter_t, Compare>
c:\local\boost_1_80_0\boost/sort/sample_sort/sample_sort.hpp(291,50): error: unexpected type name 'value_t': expected expression
c:\local\boost_1_80_0\boost/sort/sample_sort/sample_sort.hpp(291,65): error: member reference base type 'size_t' (aka 'unsigned long long') is not a structure or union
c:\local\boost_1_80_0\boost/sort/sample_sort/sample_sort.hpp(334,14): error: no member named 'return_temporary_buffer' in namespace 'std'
std::return_temporary_buffer(global_buf.first);
c:\local\boost_1_80_0\boost/sort/sample_sort/sample_sort.hpp(140,7): note: in instantiation of member function
: sample_sort(first, last, cmp, num_thread,
c:\local\boost_1_80_0\boost/sort/parallel_stable_sort/parallel_stable_sort.hpp(91,34): error: no type named 'return_temporary_buffer' in namespace 'std'
if (ptr != nullptr) std::return_temporary_buffer(ptr);
12 errors generated.
Any thoughts?
SeshaP_Intel
We were able to reproduce your issue. We have informed the development team about it.
We will get back to you soon.
Thanks and Regards,
Pendyala Sesha Srinivas
Ian_Chivers
Thanks very much for getting back so quickly. I'm in the process of moving from the classic compiler to the replacement and just wanted to bring the difference between the two to your attention.
SeshaP_Intel
Sorry for the delay in the response.
Boost relies on APIs that produce errors/warnings with newer c++ standards. For example, std::get_temporary_buffer() (used by Boost) is deprecated starting from c++17. You can refer to the below link for more details.
https://mariusbancila.ro/blog/2018/07/05/c17-removed-and-deprecated-features/
You can use /Qstd=c++17 as the workaround. icx produces warnings instead of errors and the executable runs successfully.
Please refer to the below screenshot for the output.
Thanks and Regards,
SeshaP_Intel
Has the information provided above helped? If yes, could you please confirm whether we can close this thread from our end?
Thanks and Regards,
Ian_Chivers
I apologise for not getting back sooner. My main concern was to bring to your attention differences between the Intel classic compiler and its replacement. You can close the tread as far as I'm concerned.
SeshaP_Intel
Thanks for the confirmation. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks and Regards,
