Intel® C++ Compiler
7835 Discussions
Direct-list-initialization of __m128/__m256 variable [bug, ICL 16.0]
Garipov__Ruslan
The following code produces error when get compiled by Intel C++ 16 on Windows:
    __m128 boo;
    __m128 foo {boo};
The compiler emits this error:
error : no suitable conversion function from "__m128" to "float" exists
              __m128 foo {boo};
I get the same error with `__m256` type.
This violates 8.5.4 List-initialization [dcl.init.list]:
8.5.4.3.7 Otherwise, if the initializer list has a single element of type E and either T is not a reference type or
its referenced type is reference-related to E, the object or reference is initialized from that element (by
copy-initialization for copy-list-initialization, or by direct-initialization for direct-list-initialization)...
Does it relate to "ICL can't deduce variable type when a variable is declared using a placeholder type (auto) [bug since C++17]"? I mean: is it also fixed in Intel C++ 17?
Kittur_G_Intel
Hi Ruslan,
Thanks for catching this issue. This is not fixed and I've filed an issue with the developers (CQ: DPD200408653) and will keep you updated as soon as the release with the fix is out. Appreciate your patience till then.
Kittur
Kittur_G_Intel
Hi Ruslan,
That appears to be the case and I'll check with the product team and will confirm and update you soon. Appreciate your patience till then.
Kittur
Kittur_G_Intel
Hi Ruslan,
Kittur
