I'm writing a library in which a class template relies on implicit type conversions. Hence I'd like to turn that warning off. This works well if the class is not a template, but doesn't work for templates (see code below). Am I holding this wrong?
Thanks in advance!
-Andreas
#include <iostream> #ifdef __ICC #pragma warning push #pragma warning (disable: 2304) #endif template<typename CARGO> class short_vec1 { public: // icpc issues warning #2304 fo this line even though the warning // is switched off... short_vec1(CARGO) {} }; class short_vec2 { public: // ...and not for this line (which is correct). short_vec2(double) {} }; #ifdef __ICC #pragma warning pop #endif int main() { short_vec1<double> s(4.3); short_vec2 t(4.3); }
BTW: I'm using icpc version 15.0.6 (gcc version 4.8.5 compatibility)
The warning is occurring at the point of the template instantiation (not at the point of the template declaration).
So you'd need to move the #pragma warning pop after the declaration of s in order to disable it.
Judy
Hi, Andreas
I cannot reproduce the warning with icc 15.0.6, gcc 4.8.2.
What's the compiler option you used?
Simply tried:
$ icc test.cpp -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.6.233 Build 20151119
Copyright (C) 1985-2015 Intel Corporation. All rights reserved.
Edison Design Group C/C++ Front End, version 4.8 (Nov 20 2015 02:24:47)
Copyright 1988-2013 Edison Design Group, Inc.
Hey Yolanda,
here's a gist of how I'm compiling. Strangely the warning is only issued if I add -Wnon-virtual-dtor. It doesn't occurr with -Wall only:
Thanks!
gentryx@neuromancer ~ $ icpc -V -Wall -Wnon-virtual-dtor test.cpp -o test Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0 Build 20151119 Copyright (C) 1985-2015 Intel Corporation. All rights reserved. FOR NON-COMMERCIAL USE ONLY Edison Design Group C/C++ Front End, version 4.8 (Nov 20 2015 02:24:47) Copyright 1988-2013 Edison Design Group, Inc. test.cpp(14): warning #2304: non-explicit constructor with single argument may cause implicit type conversion short_vec1(CARGO) ^ detected during instantiation of class "short_vec1<CARGO> [with CARGO=double]" at line 32 GNU ld (Gentoo 2.26.1 p1.0) 2.26.1
Judith-
My problem is that I'm a library writer. So unless all users disable this warning, they will all be spammed with warnings on code that's entirely safe. Is there a way to disable warnings from the site of the definition, not the instantiation site?
Thanks!
-Andreas
No there is not.
As already discussed in this thread
https://software.intel.com/en-us/forums/intel-c-compiler/topic/673428#comment-1881102
We shouldn't be issuing the diagnostic at all -- and this problem has been fixed recently.
Judy
K, thanks for the quick resolution!
