Intel® C++ Compiler
7838 Discussions
Does Intel Compiler use both of __INTEL_COMPILER and __GNUC__ at the same time?
jerryleo
Folloing codes will get warning #47: incompatible redefinition of macro and detected the compiler as GCC while compiling by icc.
#ifdef __INTEL_COMPILER
#define compiler "Intel"
#endif
#ifdef __GNUC__
#define compiler "GCC"
#endif
How can I detect Intel compiler by using the pre-defined compiler macros?
Jerry
TimP
Black Belt
Perhaps OP wanted something like the often used:
#if defined __INTEL_COMPILER
#define COMPILER "Intel"
#elif defined __GNUC__
#define COMPILER "GCC"
#endif
or
#endif
#if defined __GNUC__
#error "not supporting Intel gcc-compatible (e.g. linux) compilers"
#endif
#endif
TimP
Black Belt
How about putting the #ifdef __GNUC__ in a #else section, if that's what you want?
__GNUC__ has to be defined in order for header files which use it to work with icc.
Vladimir_P_1234567890
It is not 100% clear for me what TimP wrote:) so i'm re-wrtiting example
[cpp]#ifdef __INTEL_COMPILER
#else
#endif[/cpp]
--Vladimir
TimP
Black Belt
#endif
or
#endif
#endif
#endif
jerryleo
Thanks for all kindly help
Jerry
