I have a lib*.so(ia32) compiled with composer_xe_2013.1.117 integrate with eclipse, with compilation option -staic-intel .
When i want use UPX(Ultimate Packer for eXecutables) to pack lib*.so, sth wrong like:
"upx: lib*.so: CantPackException: DT_TEXTREL found; re-compile with -fPIC"
but in project properties, i have checked the -fpic option, and all other libraries(not intel-provided) has complied with -fpic already,because i have pack success when i complie the dynamic library with G++.
So, does Intel provided-libraries compiled with -fPIC? If not, Can you tell me how to re-complie the libraries?
Thanks in advance!
Georg Zitzlsberger (Intel) wrote:
That's interesting. A quick analysis showed that only libcilkrts.so contains a such a dynamic section. Even though you compile with -static libcilkrts.so might be pulled in because there's no static version of it. Can you confirm this (use -# when creating the SO)?
Edit:
If this holds true, you might compile with -no-intel-extensions to remove Intel(R) Cilk(TM) Plus support, array notations & decimal floating points -- provided that you don't use any of it.Thank you & best regards,
Georg Zitzlsberger
Hi Georg,
Yes, there is no static version of cilkrts, there is a warning in the console window:
"icpc: warning #10237: -lcilkrts linked in dynamically,static library not available"
When i re-compiled with -no-intel-extensions, the warning was disappeared, but my dynamic library(lib*.so) still cann`t pack with UPX.
It hints:" ... ,re-complie with -fPIC" as before...
Thanks for your replay!
Edit:
Georg Zitzlsberger
Hi Georg,
If not use "-axSSE3 -xSSE3 " it packed ok, but i must use SSE for speed.
I create a test program named helloworld (exe), and complied with "-axSSE3 -xSSE3 ", it`s packed ok.
i`m very lost....
I've found more libraries for IA32 that contain TEXTREL (Intel64 is OK):
composer_xe_2013.1.117/compiler/lib/ia32/libpdbx.so.5
composer_xe_2013.1.117/compiler/lib/ia32/cilk_db.so
composer_xe_2013.1.117/compiler/lib/ia32/libcilkrts.so.5If you're not using any of those, then we need to figure out which other object/library still has the TEXTREL entry.
Please get the scanelf tool (part of PaX utilities) for this. When building the SO that is brining up the error, check for the linker command (-# for our compiler) and check all dependencies via:$ scanelf -qt <object/library>
There should at least one having a TEXTREL entry. Is it coming from the system, from our compiler (already discarded this above) or from your own project (missed -fPIC)? Some systems might have "broken" SOs already - FYI:
http://www.gentoo.org/proj/en/hardened/pic-fix-guide.xmlBest regards,
Georg Zitzlsberger
This is my console ouput compile with link option -# :
Building target: libPreciseUS.so
Invoking: Intel IA-32 C++ Linker
icpc -L"/home/jk/workspace1/libs" -static-intel -# -no-intel-extensions -shared -o "libPreciseUS.so" ./Erode_Dilateh.o ./Fill_near_filed.o ./Filt_FuncProc.o ./Filter.o ./Filter2D.o ./FilterPlugin.o ./FilterUtility.o ./MeanFilter.o ./ParaInitialize.o ./Resize.o ./mainProcess.o ./stdafx.o -lm -lUserReg -lcryptopp -lpthread -ltinyxml -lRockey6SmartPlus
/opt/intel/composer_xe_2013.1.117/bin/ia32/mcpcom \
-mP1OPT_version=13.0-ia32 \
-mGLOB_diag_file=./Erode_Dilateh.diag \
-mP1OPT_print_version=FALSE \
Finished building target: libPreciseUS.so
-mCG_use_gas_got_workaround=F \
-mGLOB_gcc_version=443 \
"-mGLOB_options_string=-long_double -L/home/jk/workspace1/libs -static-intel -# -no-intel-extensions -shared -o libPreciseUS.so -lm -lUserReg -lcryptopp -lpthread -ltinyxml -lRockey6SmartPlus" \
-mGLOB_cxx_limited_range=FALSE \
-mCG_extend_parms=FALSE \
-mGLOB_compiler_bin_directory=/opt/intel/composer_xe_2013.1.117/bin/ia32 \
-mGLOB_as_output_backup_file_name=/tmp/icpc17ajbmas_.s \
-mIPOPT_activate \
-mGLOB_machine_model=GLOB_MACHINE_MODEL_PW \
-mGLOB_product_id_code=0x21006d76 \
-mCG_bnl_movbe=T \
-mP3OPT_use_mspp_call_convention \
-mP2OPT_offload_unique_var_string=icpc45289598203RjiJ \
-mP2OPT_hlo \
-mP2OPT_hpo_rtt_control=0 \
-mP2OPT_disam_assume_nonstd_intent_in=FALSE \
-mGLOB_imf_mapping_library=/opt/intel/composer_xe_2013.1.117/bin/ia32/libiml_attr.so \
-mIPOPT_link \
-mIPOPT_ipo_activate \
-mIPOPT_mo_activate \
-mIPOPT_source_files_list=/tmp/icpcslisMbt5Ua \
-mIPOPT_mo_global_data \
-mIPOPT_link_script_file=/tmp/icpcscriptV5Ci0T \
-mIPOPT_link_version=2.20.1-system.20100303 \
"-mIPOPT_cmdline_link="/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/crti.o" "/usr/lib/gcc/i486-linux-gnu/4.4.3/crtbeginS.o" "--eh-frame-hdr" "--build-id" "-shared" "-m" "elf_i386" "-L/home/jk/workspace1/libs" "-o" "libPreciseUS.so" "-L/opt/intel/composer_xe_2013.1.117/compiler/lib/ia32" "-L/opt/intel/composer_xe_2013.1.117/ipp/../compiler/lib/ia32" "-L/opt/intel/composer_xe_2013.1.117/ipp/lib/ia32" "-L/opt/intel/composer_xe_2013.1.117/compiler/lib/ia32" "-L/opt/intel/composer_xe_2013.1.117/mkl/lib/ia32" "-L/opt/intel/composer_xe_2013.1.117/tbb/lib/ia32" "-L/opt/intel/composer_xe_2013.1.117/compiler/lib/ia32" "-L/opt/intel/composer_xe_2013.1.117/ipp/../compiler/lib/ia32" "-L/opt/intel/composer_xe_2013.1.117/ipp/lib/ia32" "-L/opt/intel/composer_xe_2013.1.117/compiler/lib/ia32" "-L/opt/intel/composer_xe_2013.1.117/mkl/lib/ia32" "-L/opt/intel/composer_xe_2013.1.117/tbb/lib/ia32" "-L/opt/intel/composer_xe_2013.1.117/compiler/lib/ia32" "-L/usr/lib/gcc/i486-linux-gnu/4.4.3/" "-L/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/" "-L/lib/../lib/" "-L/usr/lib/../lib/" "-L/opt/intel/composer_xe_2013.1.117/compiler/lib/ia32/" "-L/opt/intel/composer_xe_2013.1.117/ipp/../compiler/lib/ia32/" "-L/opt/intel/composer_xe_2013.1.117/ipp/lib/ia32/" "-L/opt/intel/composer_xe_2013.1.117/mkl/lib/ia32/" "-L/opt/intel/composer_xe_2013.1.117/tbb/lib/ia32/" "-L/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../" "-L/lib/" "-L/usr/lib/" "-L/usr/lib/i486-linux-gnu" "./Erode_Dilateh.o" "./Fill_near_filed.o" "./Filt_FuncProc.o" "./Filter.o" "./Filter2D.o" "./FilterPlugin.o" "./FilterUtility.o" "./MeanFilter.o" "./ParaInitialize.o" "./Resize.o" "./mainProcess.o" "./stdafx.o" "-L/opt/intel/composer_xe_2013.1.117/compiler/lib/ia32" "-Bstatic" "-limf_pic" "-Bdynamic" "-lm" "-lUserReg" "-lcryptopp" "-lpthread" "-ltinyxml" "-lRockey6SmartPlus" "-Bstatic" "-limf_pic" "-lsvml" "-lirng" "-Bdynamic" "-lm" "-Bstatic" "-lipgo_pic" "-Bdynamic" "-lstdc++" "-lgcc" "-lgcc_s" "-Bstatic" "-lirc_pic" "-lsvml" "-Bdynamic" "-lc" "-lgcc" "-lgcc_s" "-Bstatic" "-lirc_s_pic" "-Bdynamic" "-ldl" "-lc" "/usr/lib/gcc/i486-linux-gnu/4.4.3/crtendS.o" "/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/crtn.o"" \
-mIPOPT_il_in_obj \
-mIPOPT_ipo_activate_warn=FALSE \
-mIPOPT_obj_output_file_name=/tmp/ipo_icpc8XmTpO.o \
-mIPOPT_whole_archive_fixup_file_name=/tmp/icpcwarchdWF5ab \
-mGLOB_linker_version=2.20.1-system.20100303 \
-mGLOB_driver_tempfile_name=/tmp/icpctempfileI9NUkU \
-mP3OPT_asm_target=P3OPT_ASM_TARGET_GAS \
-mGLOB_obj_output_file=/tmp/ipo_icpc8XmTpO.o \
-mGLOB_source_dialect=GLOB_SOURCE_DIALECT_NONE \
-mP1OPT_source_file_name=ipo_out.c \
./Erode_Dilateh.o \
./Fill_near_filed.o \
./Filt_FuncProc.o \
./Filter.o \
./Filter2D.o \
./FilterPlugin.o \
./FilterUtility.o \
./MeanFilter.o \
./ParaInitialize.o \
./Resize.o \
./mainProcess.o \
./stdafx.o \
-mIPOPT_object_files=T \
-mIPOPT_assembly_files=/tmp/icpcalis8k3gAg \
-mIPOPT_generated_tempfiles=/tmp/icpcelisVHltFZ \
-mIPOPT_embedded_object_base_name=/tmp/icpceobj6uPFKI \
-mIPOPT_cmdline_link_new_name=/tmp/icpcllisZuuSPr
ld \
/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/crti.o \
/usr/lib/gcc/i486-linux-gnu/4.4.3/crtbeginS.o \
--eh-frame-hdr \
--build-id \
-shared \
-m \
elf_i386 \
-L/home/jk/workspace1/libs \
-o \
libPreciseUS.so \
-L/opt/intel/composer_xe_2013.1.117/compiler/lib/ia32 \
-L/opt/intel/composer_xe_2013.1.117/ipp/../compiler/lib/ia32 \
-L/opt/intel/composer_xe_2013.1.117/ipp/lib/ia32 \
-L/opt/intel/composer_xe_2013.1.117/mkl/lib/ia32 \
-L/opt/intel/composer_xe_2013.1.117/tbb/lib/ia32 \
-L/usr/lib/gcc/i486-linux-gnu/4.4.3/ \
-L/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/ \
-L/lib/../lib/ \
-L/usr/lib/../lib/ \
-L/opt/intel/composer_xe_2013.1.117/compiler/lib/ia32/ \
-L/opt/intel/composer_xe_2013.1.117/ipp/../compiler/lib/ia32/ \
-L/opt/intel/composer_xe_2013.1.117/ipp/lib/ia32/ \
-L/opt/intel/composer_xe_2013.1.117/mkl/lib/ia32/ \
-L/opt/intel/composer_xe_2013.1.117/tbb/lib/ia32/ \
-L/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../ \
-L/lib/ \
-L/usr/lib/ \
-L/usr/lib/i486-linux-gnu \
./Erode_Dilateh.o \
./Filt_FuncProc.o \
./Filter.o \
./Filter2D.o \
./FilterPlugin.o \
./FilterUtility.o \
./MeanFilter.o \
./Resize.o \
./mainProcess.o \
./stdafx.o \
-Bstatic \
-limf_pic \
-Bdynamic \
-lm \
-lUserReg \
-lcryptopp \
-lpthread \
-ltinyxml \
-lRockey6SmartPlus \
-Bstatic \
-limf_pic \
-lsvml \
-lirng \
-Bdynamic \
-lm \
-Bstatic \
-lipgo_pic \
-Bdynamic \
-lstdc++ \
-lgcc \
-lgcc_s \
-Bstatic \
-lirc_pic \
-lsvml \
-Bdynamic \
-lc \
-lgcc \
-lgcc_s \
-Bstatic \
-lirc_s_pic \
-Bdynamic \
-ldl \
-lc \
/usr/lib/gcc/i486-linux-gnu/4.4.3/crtendS.o \
rm /tmp/icpclibgccVeAZls
rm /tmp/icpcgnudirseQb8pb
rm /tmp/icpcolis7834ux
rm /tmp/icpcalis8k3gAg
rm /tmp/icpcelisVHltFZ
rm /tmp/icpcllisZuuSPr
rm /tmp/icpcslisMbt5Ua
rm /tmp/icpcscriptV5Ci0T
rm /tmp/ipo_icpc8XmTpO.o
rm /tmp/icpcgase5gw5C
rm /tmp/icpc17ajbmas_.s
rm /tmp/icpcldashvmMT6g5
rm /tmp/icpcgnudirs1CzsnO
rm /tmp/icpcgnudirsskKlux
rm /tmp/icpcldashvhiPKBg
rm /tmp/icpcgnudirskLoFJZ
rm /tmp/icpcgnudirs5oibSI
rm /tmp/icpcgnudirsMO9g1r
rm /tmp/icpctempfileI9NUkU
rm /tmp/icpcarg9ezMuD
10:19:42 Build Finished (took 18s.545ms)
I check all object file compiled by my cpp file and all my static library is ok by scanelf program.
I think i`m not use the libs you mentioned that contain TEXTREL for ia32.
And there is only one "broken" SO, not used:
jk@ubuntu:~/statifier-1.7.2/src$ scanelf -lpqt
TEXTREL /usr/lib/1libdv.so.4.0.31
-mIPOPT_activate \
-mCG_bnl_movbe=T \
-mP2OPT_hlo \
-mIPOPT_link \
-mIPOPT_il_in_obj \
./Erode_Dilateh.o \
./Filt_FuncProc.o \
./Filter.o \
./Filter2D.o \
./FilterPlugin.o \
./FilterUtility.o \
./MeanFilter.o \
./Resize.o \
./mainProcess.o \
./stdafx.o \
ld \
--eh-frame-hdr \
--build-id \
-shared \
-m \
elf_i386 \
-o \
libPreciseUS.so \
-L/lib/../lib/ \
-L/lib/ \
-L/usr/lib/ \
./Erode_Dilateh.o \
./Filt_FuncProc.o \
./Filter.o \
./Filter2D.o \
./FilterPlugin.o \
./FilterUtility.o \
./MeanFilter.o \
./Resize.o \
./mainProcess.o \
./stdafx.o \
-Bstatic \
-limf_pic \
-Bdynamic \
-lm \
-lUserReg \
-lcryptopp \
-lpthread \
-ltinyxml \
-Bstatic \
-limf_pic \
-lsvml \
-lirng \
-Bdynamic \
-lm \
-Bstatic \
-lipgo_pic \
-Bdynamic \
-lstdc++ \
-lgcc \
-lgcc_s \
-Bstatic \
-lirc_pic \
-lsvml \
-Bdynamic \
-lc \
-lgcc \
-lgcc_s \
-Bstatic \
-lirc_s_pic \
-Bdynamic \
-ldl \
-lc \
It`s possible compiled with SSE will link some libs that will link the libs you mentioned before that for ia32 contatins TEXTREL?
jk@ubuntu:~/upx-3.08-i386_linux$ scanelf -T libPreciseUS.so
TYPE TEXTRELS FILE
libPreciseUS.so: (memory/data?) [0x699D1] in (optimized out: previous __svml_pow2_mask) [0x699D0]
libPreciseUS.so: (memory/data?) [0x699EF] in (optimized out: previous __svml_pow2_mask_dispatch_table_init) [0x699E0]
libPreciseUS.so: (memory/data?) [0x699F4] in (optimized out: previous __svml_pow2_mask_dispatch_table_init) [0x699E0]
libPreciseUS.so: (memory/data?) [0x69A11] in (optimized out: previous __svml_pow2) [0x69A10]
libPreciseUS.so: (memory/data?) [0x69A2F] in (optimized out: previous __svml_pow2_dispatch_table_init) [0x69A20]
libPreciseUS.so: (memory/data?) [0x69A34] in (optimized out: previous __svml_pow2_dispatch_table_init) [0x69A20]
libPreciseUS.so: (memory/data?) [0x69A5D] in (optimized out: previous __svml_pow2_mask_w7) [0x69A50]
libPreciseUS.so: (memory/data?) [0x69A96] in (optimized out: previous __svml_pow2_mask_n9) [0x69A80]
libPreciseUS.so: (memory/data?) [0x69BE8] in (optimized out: previous _vmldPow_HA_scalar) [0x69AB0]
libPreciseUS.so: (memory/data?) [0x69C01] in (optimized out: previous _vmldPow_HA_scalar) [0x69AB0]
libPreciseUS.so: (memory/data?) [0x69C3C] in (optimized out: previous _vmldPow_HA_scalar) [0x69AB0]
libPreciseUS.so: (memory/data?) [0x69C59] in (optimized out: previous _vmldPow_HA_scalar) [0x69AB0]
libPreciseUS.so: (memory/data?) [0x69CAE] in (optimized out: previous _vmldPow_HA_scalar) [0x69AB0]
libPreciseUS.so: (memory/data?) [0x69CD6] in (optimized out: previous _vmldPow_HA_scalar) [0x69AB0]
libPreciseUS.so: (memory/data?) [0x69D12] in (optimized out: previous _vmldPow_HA_scalar) [0x69AB0]
libPreciseUS.so: (memory/data?) [0x69D30] in (optimized out: previous _vmldPow_HA_scalar) [0x69AB0]
libPreciseUS.so: (memory/data?) [0x69D63] in (optimized out: previous _vmldPow_HA_scalar) [0x69AB0]
libPreciseUS.so: (memory/data?) [0x69DAB] in (optimized out: previous _vmldPow_HA_scalar) [0x69AB0]
libPreciseUS.so: (memory/data?) [0x69DC4] in (optimized out: previous _vmldPow_HA_scalar) [0x69AB0]
libPreciseUS.so: (memory/data?) [0x69DFE] in (optimized out: previous _vmldPow_HA_scalar) [0x69AB0]
libPreciseUS.so: (memory/data?) [0x69E4C] in (optimized out: previous _vmldPow_HA_scalar) [0x69AB0]
libPreciseUS.so: (memory/data?) [0x69E5F] in (optimized out: previous _vmldPow_HA_scalar) [0x69AB0]
libPreciseUS.so: (memory/data?) [0x6A046] in (optimized out: previous pow_scalar) [0x69FB0]
TYPE TEXTRELS FILE
libPreciseUS.so: (memory/data?) [0x69991] in (optimized out: previous __svml_pow2_mask) [0x69990]
libPreciseUS.so: (memory/data?) [0x699AF] in (optimized out: previous __svml_pow2_mask_dispatch_table_init) [0x699A0]
libPreciseUS.so: (memory/data?) [0x699B4] in (optimized out: previous __svml_pow2_mask_dispatch_table_init) [0x699A0]
libPreciseUS.so: (memory/data?) [0x699D1] in (optimized out: previous __svml_pow2) [0x699D0]
libPreciseUS.so: (memory/data?) [0x699EF] in (optimized out: previous __svml_pow2_dispatch_table_init) [0x699E0]
libPreciseUS.so: (memory/data?) [0x699F4] in (optimized out: previous __svml_pow2_dispatch_table_init) [0x699E0]
libPreciseUS.so: (memory/data?) [0x69A1D] in (optimized out: previous __svml_pow2_mask_w7) [0x69A10]
libPreciseUS.so: (memory/data?) [0x69A56] in (optimized out: previous __svml_pow2_mask_n9) [0x69A40]
libPreciseUS.so: (memory/data?) [0x69BA8] in (optimized out: previous _vmldPow_HA_scalar) [0x69A70]
libPreciseUS.so: (memory/data?) [0x69BC1] in (optimized out: previous _vmldPow_HA_scalar) [0x69A70]
libPreciseUS.so: (memory/data?) [0x69BFC] in (optimized out: previous _vmldPow_HA_scalar) [0x69A70]
libPreciseUS.so: (memory/data?) [0x69C19] in (optimized out: previous _vmldPow_HA_scalar) [0x69A70]
libPreciseUS.so: (memory/data?) [0x69C6E] in (optimized out: previous _vmldPow_HA_scalar) [0x69A70]
libPreciseUS.so: (memory/data?) [0x69C96] in (optimized out: previous _vmldPow_HA_scalar) [0x69A70
uchar* kernel = (uchar *)malloc(sizeof(uchar)*kersize.width*kersize.height);
for( i = 0;i< kersize.width*kersize.height; i++)
kernel=_kernel;
Compile this few line code above, and use scanelf -T liblibtest.so. output is:
jk@ubuntu:~/upx-3.08-i386_linux$ scanelf -T liblibtest.so
TYPE TEXTRELS FILE
liblibtest.so: (memory/data?) [0x16BF9] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16C08] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16C4D] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16C56] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16C5E] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16C67] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16CBC] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16CC2] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16D9F] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16DB1] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16DB7] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16DBD] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16DDD] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16ED7] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16EF7] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16EFE] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16F0B] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16F1E] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16F2D] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16F33] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16F39] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16F3F] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x16F72] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x17022] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x17028] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x1702E] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x17034] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x1703A] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x17040] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x17046] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x1704C] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x17052] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x17058] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x1705E] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x17064] in (optimized out: previous __cacheSize) [0x16BE0]
liblibtest.so: (memory/data?) [0x17084] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17091] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1709E] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x170E3] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x170ED] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x170F6] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1710A] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17112] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1711D] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17128] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17132] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17137] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17142] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1714B] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17153] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1715C] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17258] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1725F] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17269] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1726F] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x172B7] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x172C3] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x172CF] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x172DB] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17329] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1732F] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17406] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17418] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1741E] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17424] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1743B] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17526] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17546] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1754D] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1755A] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1756D] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1757C] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17582] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17588] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1758E] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x175B8] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1765F] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17665] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1766B] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17671] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17677] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1767D] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17683] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17689] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1768F] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x17695] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x1769B] in (optimized out: previous __sti__$E) [0x17070]
liblibtest.so: (memory/data?) [0x176A1] in (optimized out: previous __sti__$E) [0x17070]
ET_DYN liblibtest.so
jk@ubuntu:~/upx-3.08-i386_linux$ ./upx liblibtest.so
Copyright (C) 1996 - 2011
UPX 3.08 Markus Oberhumer, Laszlo Molnar & John Reiser Dec 12th 2011
File size Ratio Format Name
upx: liblibtest.so: CantPackException: DT_TEXTREL found; re-compile with -fPIC
I did a try with update 3 and still get this issue when link svml library statically.
With dynamic link of this library it is working fine.
Thanks in advance.
this is reported to be fixed with the next update: Intel(R) Composer XE 2013 Update 3
Georg Zitzlsberger
I compile it with -no-intel-extensions and it doesnt help.
Here is libraries used in project:
/opt/intel/ipp/lib/ia32/libippcc_l.a \
/opt/intel/ipp/lib/ia32/libippi_l.a \
/opt/intel/ipp/lib/ia32/libipps_l.a \
/opt/intel/ipp/lib/ia32/libippvc_l.a \
/opt/intel/ipp/lib/ia32/libippcore_l.a \
/home/default/workspace/displayHD/codec/ffmpeg/lib/linux/ia32/libavcodec.so.53.20.1 \
/home/default/workspace/displayHD/codec/ffmpeg/lib/linux/ia32/libavutil.so.51.21.0 \
/home/default/workspace/displayHD/freetype/lib/linux/ia32/libfreetype.a \
/home/default/workspace/displayHD/codec/h264/lib/linux/ia32/libevo264enc.so \
/opt/intel/tbb/lib/ia32/gcc4.1/libtbbmalloc.so.2 \
/opt/intel/tbb/lib/ia32/gcc4.1/libtbb.so.2 \
/opt/boost/lib/ia32/libboost_thread-il132-mt-s-1_48.a \
/opt/boost/lib/ia32/libboost_system-il132-mt-s-1_48.a \
/opt/intel/ipp/lib/ia32/libippj_l.a \
/opt/intel/ipp/lib/ia32/libippcv_l.a \
/opt/intel/ipp/lib/ia32/libippdc_l.a \
/opt/intel/ipp/lib/ia32/libippch_l.a \
-ljawt \
-lpthread \
-lXrandr \
-lX11 \
-lGLU \
-lGL \
-lrt \
-Bsymbolic \
-rpath \
$ORIGIN \
-Bstatic \
-limf_pic \
-lsvml \
-lirng \
-Bdynamic \
-lm \
-Bstatic \
-lipgo_pic \
-ldecimal \
--as-needed \
-Bdynamic \
-lcilkrts \
--no-as-needed \
-lstdc++ \
-lgcc \
-lgcc_s \
-lpthread \
-Bstatic \
-lirc_pic \
-lsvml \
-Bdynamic \
-lc \
-lgcc \
-lgcc_s \
-Bstatic \
-lirc_s_pic \
-Bdynamic \
-ldl \
-lc \
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/32/crtendS.o \
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../crtn.o
Here is output information about TEXTREL:
[default@localhost boost-build]$ eu-findtextrel bin/RELEASE_PLUGIN_32/libvievoLib.so
the file containing the function '__svml_cos2' is not compiled with -fpic/-fPIC
either the file containing the function '__svml_cos2' or the file containing the function '__svml_floor2' is not compiled with -fpic/-fPIC
either the file containing the function '__svml_floor2' or the file containing the function '__svml_floor2_w7' is not compiled with -fpic/-fPIC
either the file containing the function '__svml_floor2_n9' or the file containing the function '__svml_feature_flag_init' is not compiled with -fpic/-fPIC
either the file containing the function 'own_pj_twoexpnminusone' or the file containing the function 'ft_bitmap_glyph_class' is not compiled with -fpic/-fPIC
Note that compilation libsvml library dynamically has no problem with TEXTREL.
Hope this information is helpful for you.
Thanks in advance.
I've checked the libraries we ship with our compiler (Intel(R) Composer XE 2013 Update 3) and still found Intel(R) Cilk(TM) Plus to have TEXTRELs. Hence I've reopened the ticket.
Does compiling/linking with -no-intel-extensions help this time? If not, then there's another library with a TEXTREL section linked in. Could you find out which one? The compiler seems to have no further ones. If other components of the Composer package contain TEXTRELs I'd need to forward that information to the respective team.
Georg Zitzlsberger
