http://www.google.com/url?sa=t&source=web&ct=res&cd=10&ved=0CD0QFjAJ&url=http%3A%2F%2Fsoftware.intel.com%2Ffile%2F19151&rct=j&q=xgetbv+site%3Aintel.com&ei=vs3iS5usHIbgM9auxagD&usg=AFQjCNHyGPOcmoAU0A5oiC-5Y55I-0AHvQ
aka software.intel.com/file/19151
"Advanced Vector Extensions Programming Reference"
The bug is related to the xsave instruction - see thisarticle:http://software.intel.com/en-us/articles/program-crashes-or-hangs-on-some-systems/.
It only happens on those machines that have the xsave instruction turned on from both hardware level AND OS level. For Windows OS my research shows that the Windows 7* has it turned on, so as the Windows Server 2008* R2. Hardware level, it's very difficult to list all of them. But if you follow the instructions from MSDN website here: http://msdn.microsoft.com/en-us/library/ms724482(VS.85).aspx, you can write a simple program to detect if the xsave instruction is enabled.
There is no sure way to patch the binary, so we recommend updating the compiler to the latest 11.1 update and rebuild your application.
Thank you!
Jennifer
