I have just noticed that the LDLT decomposition is broken with the latest Intel compiler.icpc version 18.0.1 (gcc version 6.4.0 compatibility)
Comparing the solutions for a random SPD matrix obtained with FullPivLU, PartialPivLU, LLT and LDLT shows that the latter is broken. You can find the code for this test on GitHub: https://github.com/robertodr/ eigen-cholesky
Intel 18.0.1 results
Linear system solvers comparison
Relative error |Ax - b| / |b|
FullPivLU 2.74599e-11
PartialPivLU 1.37848e-11
LLT 1.70863e-11
LDLT 7.02994
Error wrt FullPivLU |x - x_flu| / |x_flu|
PartialPivLU 1.91271e-11
LLT 8.91642e-11
LDLT 1.00003
LLT 1.70863e-11
LDLT 7.02994
LLT 8.91642e-11
LDLT 1.00003
GCC 6.4.0 results
LLT 1.54872e-11
LDLT 2.0482e-11
LLT 3.25784e-11
LDLT 1.47468e-10
LLT 1.54872e-11
LDLT 2.0482e-11
LLT 3.25784e-11
LDLT 1.47468e-10
The sample works with Intel 17 and 18.0.0 Compiling in debug mode also fixes the issue. The Eigen developers suggested setting -fp-model precise but that didn't help
Thanks in advance for any suggestions.
Roberto
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
I'm having the same problem as you, Roberto. Did you manage to find the solution to this elsewhere btw? Any suggestions would be appreciated!
Have you tried different setting for -fp-model= strict, consistent, source...?
Viet
Turning on optimizations and using -fp-model strict fixes the problem. None of the other -fp-model flags works though.
