Dear Experts,
I have recently downloaded and installed parallel_studio_xe_2018_update1_cluster_edition for a single user on my linux environment (Debian 9.1). The installation was successful however when i try to set variables in the command line with:
$HOME/intel/bin/iccvars.sh intel64
I get the following error:
Syntax: source daalvars.sh <arch>
Where <arch> is one of:
ia32 - setup environment for IA-32 architecture
intel64 - setup environment for Intel(R) 64 architectureIf the arguments to the sourced script are ignored (consult docs for
your shell) the alternative way to specify target is environment
variables COMPILERVARS_ARCHITECTURE or DAALVARS_ARCHITECTURE to pass
<arch> to the script.ERROR: Architecture is not defined. Accepted values: ia32, intel64
ERROR: Architecture is not defined. Accepted values: ia32, intel64ERROR: architecture is not defined. Accepted values: ia32, intel64
Syntax:
source mklvars.sh <arch> [MKL_interface] [mod]<arch> must be one of the following
ia32 : Setup for IA-32 architecture
intel64 : Setup for Intel(R) 64 architecturemod (optional) - set path to Intel(R) MKL F95 modules
MKL_interface (optional) - Intel(R) MKL programming interface for intel64
Not applicable without mod
lp64 : 4 bytes integer (default)
ilp64 : 8 bytes integerIf the arguments to the sourced script are ignored (consult docs for
variables COMPILERVARS_ARCHITECTURE or MKLVARS_ARCHITECTURE to pass
<arch> to the script, MKLVARS_INTERFACE to pass <MKL_interface> and
MKLVARS_MOD to pass <mod>ERROR: architecture is not defined. Accepted values: ia32, intel64
Syntax: ippvars.sh <arch> [-arch <arch>] [-platform <platform>]<arch> must be one of the following:
ia32 : Set up for IA-32 target.
intel64 : Set up for Intel(R)64 target.
<platform> must be of the following:
linux : Set to Linux target.
mac : Set to Mac target.
android : Set to Android target.If the arguments to the sourced script are ignored (consult docs
for your shell) the alternative way to specify target is environment
variables COMPILERVARS_ARCHITECTURE to pass <arch> to the script
and COMPILERVARS_PLATFORM to pass <platform>
/home/animeshs/intel/bin/iccvars.sh: 42: [: =: unexpected operator
/home/animeshs/intel/bin/iccvars.sh: 50: [: =: unexpected operator
/home/animeshs/intel/bin/iccvars.sh: 159: [: =: unexpected operator
/home/animeshs/intel/bin/iccvars.sh: 171: [: =: unexpected operator
Kindly help me know how to proceed?
Ani
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Can you try:
$source $HOME/intel/bin/compilervars.sh intel64
Viet
That worked Viet, thanks :) However i am still not able to use the compiler, seems to be unable to "fork process:":
➜ openmp_samples make
Cleaning...
icc -c -O2 -std=c99 -wd3180 -qopenmp -o out/openmp_sample.o src/openmp_sample.c
icc: error #10103: can't fork process: Invalid argument
Makefile:35: recipe for target 'out/openmp_sample.o' failed
make: *** [out/openmp_sample.o] Error 1
The code it from openmp samples from intel.
Any suggestions to move forward will be very much appreciated :)
Can you see if it works on "helloworld.c"?
$icc -O2 helloworld.c -c -o helloworld.o
It is the same error:
turns out that simple icc invokation has same issue:
icc
I don't know what happened. You could try "$strace -f icc -O2 helloworld.c -c >& strace.txt to see why you get "Invalid argument"
It says (attached full report):
execve("/home/animeshs/intel/compilers_and_libraries_2018.1.163/linux/bin/intel64/icc", ["icc", "-O2", "helloworld.c", "-c"], [/* 40 vars */]) = 0
brk(NULL) = 0xdf8000
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
could it be that installation has some prereqs which are not there?
Have you installed GCC? ICC uses the GNU C/C++ linker/librarian.
Jim Dempsey
Hello, if you want to move forward try to use bash:)
It looks that you use dash. In theory icc should work under dash but as far as I remember there should be some additional steps to setup bash compatible-environment to dash-compatible environment.
--Vladimir
Yes Jim, there is GCC in the system and it works:
animeshs@DMED7596:~/ray$ gcc helloworld.c
animeshs@DMED7596:~/ray$ ./a.out
hello
It can also compile openmpi based program https://github.com/sebhtml/ray flawlessly. It still takes a lot of time, so the reason i wanted to try out intel compiler is to check if i do get any speed advantage :)
Yes Vladimir, it is ZSH actually :) But i tried your suggestion of bash without much success:
animeshs@DMED7596:~/ray$ icc helloworld.c
I suspect some issue with how icc is calling ld, but no idea since cpp is not what i know much of for sure...
